I just bought a Bluray drive from my computer which I haven't received yet (ordered it online). I have been using another DVD program to play DVDs without issue but decided to go ahead and buy WinDVD because it was cheaper than trying to upgrade the other program to play BD.
After installing WinDVD, when I try playing any DVD using WinDVD, I get the message that "your display environment does not support protected content". I can play that DVD fine in the other DVD program. Again, I haven't even got my BD drive nor do I own any BDs and I am only trying to play DVDs at this point.
Also (if related), on the WinDVD program start screen, shouldn't there be a DVD logo along with the logos for Bluray that represent the enabled features? Mine just has five icons representing AVCHD, AVCREC, Bluray, BDLive & Bonus View. Or am I just being paranoid?
Moderator: lata
steamwalker
- motherboard: ASUS M4A77TD
- processor: AMD Phenom II X4 965 Black Edition Deneb 3.4GHz
- ram: 4GB
- Video Card: BFG Tech GeForce GTX 260 OCX
- sound_card: Integrated
- Hard_Drive_Capacity: 2TB
nepenthe
- motherboard: Gigabyte GA-P55A-UD3P
- processor: i-7 860
- ram: 16 GB
- Video Card: Gigabyte GeForce GTX 470 SOC
- sound_card: onboard Realtec audio
- Hard_Drive_Capacity: 600 GB
- Monitor/Display Make & Model: NEC MultiSync EA192M
Re: your display environment does not support protected cont
This may be an HDCP noncompliant monitor issue. HDCP (High Definition Content Protection) compliance will usually appear in the specifications: DVI (HDCP Compliant). So check your monitor's specs at the manufacturer's website. If the monitor isn't HDCP compliant, you must seriously consider replacing it.
nepenthe
- ram: 16 GB
Addendum - I posted an earlier reply, raising the question of an HDCP non-compliant monitor. I should add that HDCP actually refers to High Definition Digital Content Protection, which controls your DVI monitor cabling. However, you may still be able to view content if your graphics processor card has a VGA port and you can run analog VGA cabling to your monitor. I suppose that defeats the purpose of high definition video, but is a possible interim workaround pending monitor replacement.
steamwalker
- ram: 4GB
I was able to solve my issue but using the VGA cable instead of the DVI. I did buy a new monitor so I am back to DVI/HDMI now. Issue was WinDVD for some reason won't allow even regular DVDs to play without a HDCP supported digital connection whereas the other software would.
