I need to help/suggestions for this "problem".
Scenario: I have several videos rendered by VS X3 in MPEG2 DVD 4:3 resolution and I want to create a DVD (I used the standard template in VS X3 for DSD).
I use DVDMF7SE, put all the videos, burn the DVD, play on my flat screen TV... it happens that, compared to what I can see when the videos are played on the PC, on the TV the videos are slithly cut in the borders...
The TV screen is set to 4:3 as well.
OK... I found the "TV safe area" parameter in the DVDMF7SE in the Settings->Preference, but even changing it from 10 to 0 does not reduces the video cutted edges.
Hence, the question is: how to create a 4:3 DVD video thata will have on TV the exact size I can see on the PC ?
Thanks in advance for you help
