HELP.. WHY is the image/color duration grayed out in VS 9?:)
michelehamilton
I am in DESPERATE need of help.. I need to change the duration on all my slides.. but AFTER they are in the timeline.. with my transitions the way I want them.. In VS8.. it was no problem.. I bought the full new version of 9..and it's STILL grayed out..
WHY oh WHY??:)
THANK YOU:)
Michele;)
WHY oh WHY??:)
THANK YOU:)
Michele;)
michelehamilton
MikeGunter
Re: HELP.. WHY is the image/color duration grayed out in VS
Hi Michele,michelehamilton wrote:I am in DESPERATE need of help.. I need to change the duration on all my slides.. but AFTER they are in the timeline.. with my transitions the way I want them.. In VS8.. it was no problem.. I bought the full new version of 9..and it's STILL grayed out..
Michele;)
"What" is grayed out?
Mike
michelehamilton
MikeGunter
(still a little confused to what is greyed out)
If I want to change the duration of several images in the timelines, provided they are adjacent to each other.
In Storyboard View
I select the images by using Shift Click
I see a red border around the selected clips.
I click ‘Clip’ from the top menu (next to ‘Tools’)
I select ‘Change image / color duration’
I change the duration in the pop up window.
This changes the duration of the selected clips only.
Does this work for you?
In Storyboard View
MikeGunter
Exactly.trevor andrew wrote:
In Storyboard View
Mike
michelehamilton
michelehamilton
FOUND OUT PROBLEM
It was because the ripple thing was enabled.. it won't let you change the times.. you have to UNable it:)
THought I would let everyone know that I wasn't crazy..AND if someone else has that problem:)
Thanks!!
Michele:)
Thanks!!
Michele:)
