Editing Screencasts
kamiller42
Editing Screencasts
Post by kamiller42 »
I am having a bad case of the whole being significantly greater than the sum of its parts.
I created two AVIs using CamStudio. One is 52MB. The other is 10MB. My project has the little one being inserted in the middle of the big one. I want to output the two together into a single AVI file or another container with a CODEC a Windows user would likely have. Every time I create a file, it ends up being either way larger than the sum of the two video files, like 1.5GB(!), or I am unable to change the frame size to match the source video (880x612).
How can I create a video file which respects the specs of the original file, is viewable on most Windows systems, and doesn't result in a file 100x the size of the source files?
For reference:
GSpot reports the source files as using Microsoft Video 1 (CRAM) at 20fps with PCM audio (22Khz, 706kbs).
kamiller42
Re: Editing Screencasts
Just FYI. If I create a video the same a first file, I get a 1.1GB file. I don't think it's compressing Microsoft Video 1. 1.1GB from 60MB of source video is too much.
Are you using Techsmith's avi codec? This is more compressed than DV or MS Video 1. So converting from Camtasia Studio to MS Video 1 will produce a significantly larger file size. In Camtasia Studio try using the WMV.
kamiller42
I am using CamStudio, not Camtasia. http://camstudio.org/
I think I discovered some bugs and the source of my frustration.
Given: Windows 7 Pro 32-bit with 3GB memory
Problem 1: Program attempts to write new video encode profiles to a forbidden directory. If run as myself, click Copy on an existing profile (WMV in this case) on the Manage Profiles screen, the program fails. If I start as administrator, no problem. New profile created.
Problem 2: When saving as WMV, I review the Options and the list of profiles I can pick from. There are some under the Customize option for WMV that do not exist in the drop down, specifically the Screen Video and Screen Video/Audio profiles, which happens to be what I need.
Problem 3: Upon reviewing the Screen Video and Screen Video/Audio profiles, I notice they contain a description but no options are set when I click Edit. So, I create a New profile and select Import to import these WMV profiles. The description appears and the settings are set. Now it's looking like it's supposed to!
Problem 4: After I import the Screen Video and Screen Video/Audio profiles, they appear in the Manage Profiles list. Everything looks good. But when I go back to the Video Save Options screen, none of them appear as options in the Profiles drop down. How can I use these new profiles I created via import?
kamiller42
Hmm, no answers. I thought editing and producing screencasts would be a fairly easy thing to do.
