Video Pro X3 or Project Creator
Bouldergolfer
- motherboard: Eureka 3
- processor: Intel 2 Quad CPU Q8300 2.50 GHz
- Video Card: Seagate ST9120822AS
- sound_card: Realtek
- Hard_Drive_Capacity: 450GB
I am looking for a complete manual for Video Pro X3 or Project Creator X3. I am having extreme difficulties editing photo slideshow. Difficulties are setting display times different for each photo as well as transitions in a slideshow. Program keeps setting all photos to same display time and cannot have seperate transitions per slide. It would help greatly if I knew where to download the Video Pro X3 Complete user manual for free as well as Project Creator Manual. I found the PaintShop Pro X3 manual but doesn't get into Project Creator. Video Pro X3 came with NO manual at the download so am looking for a full manual. If anyone knows of a site for the manauls or a good tutorial on the specific subject of seperate slide display time and transitions please let me know.
Re: Video Pro X3 or Project Creator
Are you using the normal editor ("Advanced editor") or VideoStudio Express?Bouldergolfer wrote:I am having extreme difficulties editing photo slideshow. Difficulties are setting display times different for each photo as well as transitions in a slideshow. Program keeps setting all photos to same display time and cannot have seperate transitions per slide.
If you are using the Express, you need to export it back to Advanced Editor in the last output options. Once the project is in the time line, you can adjust the duration of each photo by dragging the clip or right click -> Change photo duration.
As for transition, you can change/replace any one you like.
If you are producing HD video, and find the photo blurry, this is a very important setting to change in the "Preference".
Under "Preference" -> "Edit" and "Image", UNCHECK / Turn off anti-flickering. And your slideshow instantly change from low res back to high resolution again
Sadly the only Manual/User Guide is the on-line version. Corel stopped producing a PDF version.
Bouldergolfer
I have been looking all over on-line for a User Guide / Manual for Video Pro. I found Paint Shop Pro in .pdf, but can't find anything but a little 12 page book on Video Pro. Where is the on-line version located so I can download it?
Are you wanting the User Guide for VS X2 Pro, or VS X3 Pro? If it is the latter one, Corel did not produce a download-able user guide, The only one available is on-line, web page style. You access it by clicking on the Circular button with the down-arrow, located in the upper right corner.Bouldergolfer wrote:I have been looking all over on-line for a User Guide / Manual for Video Pro. I found Paint Shop Pro in .pdf, but can't find anything but a little 12 page book on Video Pro. Where is the on-line version located so I can download it?
The user guide for VS X2 Pro (full, not trial) should have been installed when you installed the program.
