Videostudio memory usage and performance using Vista x64
Accolades
motherboard: Gigabyte GA-EX58-UD4
processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
ram: 12 GB DDR3
Video Card: Nvidia GeForce GTX 295
sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
Hard_Drive_Capacity: 4TB +
Re: Videostudio memory usage and performance using Vista x64
Post by Accolades »
If you have a look at my testing in messages above you will notice there are or should be visable 8 processes whereas yours has only 4.
Your image asls state 4 Cores - 4 Threads
Where I appear to have 4 Cores but 8 Threads :-)
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
alsbessa
Post by alsbessa »
Searching Corel Support I've found the following:
"Choosing an optimum setup for HD Video-Editing in VideoStudio"
"For 64-bit operating systems it may be worth adding more RAM for Windows to use, as they can make use of up to 8Gb of RAM. VideoStudio Pro X2, however, can only use 2Gb of RAM no matter which Operating System you use."
Does X3 use the x64 advantages like using RAM above the 2GB restriction, as stated above?
Could anybody find an advantage of VideoStudio X3 running on a x64 Windows with 8GB RAM compared to x32 with 4GB?
scubamut
operating_system: Vista Ultimate
motherboard: Asus M4A785TD-V EVO
processor: AMD Phenom II x64 965
ram: 6GB
Video Card: Onboard
sound_card: Onboard
Hard_Drive_Capacity: 1.2TB
Post by scubamut »
My experience with 64 bit Vista shows that with 64 bit codecs all 8GB I have installed is used by running Pro X2, mostly as disk cache. Take a look at some of the results I've posted in this thread. I haven't run a benchmark with 32 bit vs 64 bit Vista though...
Dave
VS Pro X2; M4A785TD-V EVO; AMD Phenom II x64 965; 6GB
GeorgeP
motherboard: HpPavilion
processor: AMD Phenom II x4 925 2.8GHz
ram: 8.0 GB
Video Card: ATI Radeon 4650
sound_card: Realtek HD audio
Hard_Drive_Capacity: 680GB
Post by GeorgeP »
I did some tests using a source file from my Canon HF100 HD camera (MTS 1440x1080) of about 80MB, rendering the clip
Scubamut,I found your 1m14sec encoding PDF report link very useful. We share the same Hf100 camera and my processor is only a bit slower. It's no surprise that I ended up with similar rendering times. I assumed that smart rendering was applied.
My question is: Have you tried to encode same duration but with 2 or 3 transitions,effect or title included?
I'm curious about encoding durations relative to the real time then. More importantly will encoded video be free of defects like skipped frames or freezing playback? 1min and 14sec may be a bit short for this test. Also complexity of your raw footage and effects will play a major role.
Accolades
ram: 12 GB DDR3
Post by Accolades »
Run further testing on my system generating video file MPG.
Timeline has an imported MPG file captured from TV card 1.39gb
Cut to 10 mins on timeline
I generate an MPG file DVD 16.9
CPU Usage does not go over 40%
Memory usage does not go over 2.9gb
My Vimeo Channel:
