Videostudio memory usage and performance using Vista x64
scubamut
operating_system: Vista Ultimate
motherboard: Asus M4A785TD-V EVO
processor: AMD Phenom II x64 965
ram: 6GB
Video Card: Onboard
sound_card: Onboard
Hard_Drive_Capacity: 1.2TB
Post by scubamut »
I'm curious as to whether anyone has played around with X2 and Vista x64 to use memory most effectively to get the best performance. Seems there are a few ways of using system RAM (and probably some I haven't thought of):
1) let Vista decide
2) create a RAMDISK use it to store source and rendered videos
3) use the RAMDISK with Vista's ReadyBoost feature enabled
Also, when rendering a video, Vista Task Manager shows all 4 of my quad processors busy, one at about 30%, the other 3 at < 5%. This, even when the source/rendered videos are all in system RAM. I had thought that the CPU would be the performacnce bottleneck, but this doesn't appear to be so. Anyone have any thoughts or advice on this?
Dave
VS Pro X2; M4A785TD-V EVO; AMD Phenom II x64 965; 6GB
Again with the caveat that I am not a 64 bit user, as I said in your other thread, X2 (and X3) were not written in a 64 bit version. Nor, unfortunately, were they apparently written to take advantage of multi-core processors.
On my own Quad running X2 originally under Vista, and now X3 under Windows 7, I got similar read-outs to you from Task Manager when rendering video. The only way I have found of boosting usage of all four cores is a little -- and cheap -- program called Ashampoo Core Tuner. I think it cost me about US$9.99, though that may have been a promotional offer at the time.
Some people pooh-pooh it. But I could actually sit there and watch all four cores go up to over 60% -- with two of them up to over 80% -- when using X2/X3 for rendering. This was also reflected in much improved rendering times, though these varied according to what format you were rendering in.
With HDV, I got nearly 4 times better rendering speed, but with AVCHD it was only a bit under 2x. But given that rendering times of high def video, if not using SmartRender (which I don't), are rather long, any improvement is both noticeable and appreciated.
Accolades
motherboard: Gigabyte GA-EX58-UD4
processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
ram: 12 GB DDR3
Video Card: Nvidia GeForce GTX 295
sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
Hard_Drive_Capacity: 4TB +
Post by Accolades »
A small test using my humble system.
Win 7 64 bit, VSX3 Registered and updated
Start file AVI
End file rendered to HDD
Average CPU/MEM usage
Some CPU and MEM usage - Not much else running..
Just to show it was actually rendering :-)
More Stats...
(image shrunk by sjj1805 Admin - too wide for proper display on Web Board)
And More Stats..
Rendering time ~1.5hrs tried to get the best quality using double sampling, but not impressed with output.
Maybe there are other options I should have chosen?
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
Re: Videostudio memory usage and performance using Vista x64
scubamut wrote:I'm curious as to whether anyone has played around with X2 and Vista x64 to use memory most effectively to get the best performance. Seems there are a few ways of using system RAM (and probably some I haven't thought of):
I only have a humble core 2 Duo on a 32 bit system.
I did plug in an 8GB USB flash drive
To be honest the concept is good but in reality it is a gimmick because the data still has to be written / read to and from the USB drive and they are slowww
While the extra "RAM" might allow you to install any software that insists you have "x" amount of RAM available and will refuse to let you install with less, that is where its usefulness ends. I found that by using this ready boost RAM it actually made my computer run slower.
Accolades
ram: 12 GB DDR3
Post by Accolades »
Downloaded 10 day trial of CORE TUNER
Tested with same file ro create IMAGE.
My Vimeo Channel:
So no significant difference or improvement for you... Hmmm... :cry:
Accolades
ram: 12 GB DDR3
Post by Accolades »
Was a little surprised that my web browser - Firefox used up as much CPU as Video Studio did rendering a video :-| ?
I am now trying to force myself to use Internet Explorer 8 instead....
Win having Win 7 64bit Installed I also have the option of using a 64bit Internet Explorer. Unfortuanately the 64 bit version does not support any FLASH and Shockwave media. :-(
As MOST websites have some sort of the above embedded it sort of makes it a little useless!!
Back to the 32bit version of IE which according to the process viewer uses 0% of CPU!!
My Vimeo Channel:
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Post by aljimenez »
Firefox should not be active, unless you have many tabs with webpages that are updating themselves and/or playing videos. Just make sure you click the stop icon for each web-page you have when rendering... Al
User for more than 10 years.
Accolades
ram: 12 GB DDR3
Post by Accolades »
aljimenez wrote:Firefox should not be active, unless you have many tabs with webpages that are updating themselves and/or playing videos. Just make sure you click the stop icon for each web-page you have when rendering... Al
All fixed - think it has something to do with JAVA on start has 0% useage but after a while go to ~14% no biggie...
My Vimeo Channel:
scubamut
ram: 6GB
Video Card: Onboard
sound_card: Onboard
Post by scubamut »
Thks for the comments.
I did some tests using a source file from my Canon HF100 HD camera (MTS 1440x1080) of about 80MB, rendering the clip as:
1. AVCHD 1920
2. Blu-ray 1920
3. HDV 1080
4. WMV 1080
5. Zune h264 640x480
6. Mpeg Optimizer (which retains the source format)
I timed each (manually, so the times are probably +- a few secs) using these memory cofigurations:
1. Vista decides
2. 4 GB RAMDISK (VSuite Standard Edition))
3. Vista ReadyBoost
In summary, the results show:
1. Neither RAMDISK nor ReadyBoost have a meaningful effect on rendering speed => seems Vista uses available memory to cache data from disk anyway
2. What may be useful are the relative speeds: Mpeg Optimizer is at least 5x as fast as any other output format and the resulting file has the same format and size (approximately) of the source file. You may want to bear this in mind when editing.
3. All 4 processors in the Quad Phenom II x64 965 chip are active during processing without the help of any additional utilities - I would guess that this is probably the result of using 64 bit codecs, not necessarily VS itself.
You can find the details here, if interested.
Dave
Accolades
ram: 12 GB DDR3
Post by Accolades »
Assuming you turned Hyperthreading off in BIOS ?
My Vimeo Channel:
Accolades
ram: 12 GB DDR3
Post by Accolades »
scubamut wrote:Thks for the comments.
1. AVCHD 1920
2. Blu-ray 1920
3. HDV 1080
4. WMV 1080
Couldnt see any times posted on the link?
My Vimeo Channel:
scubamut
ram: 6GB
Video Card: Onboard
sound_card: Onboard
Post by scubamut »
I gave rough relative times (as I said, the timing was manual), "1" being about 20 secs.
Dave
Accolades
ram: 12 GB DDR3
Post by Accolades »
Did you manually disable Hyperthreading in Bios ?
Why ?
My Vimeo Channel:
scubamut
ram: 6GB
Video Card: Onboard
sound_card: Onboard
Post by scubamut »
Accolades wrote:Did you manually disable Hyperthreading in Bios ?
Why ?
Why do you say hyperthreading is disabled??
Dave
