Unable to burn to DVD with VS11+
ibbotson
Post by ibbotson »
Having found my way around the capturing process with a lot of help from members of this forum I am now having problem burning to DVD. I can go all through the process of capture, editing & rendering without any problems but the final process of burning fails. I can burn via VS6 so I'm sure there is no problem with drive.
I need to burn to to 8.5gb double layer disc's owing to size of video files. VS11+ has this option but VS6 does not, "unless I'm wrong" so can not use VS6 for the burn process. I have also tried 4.7 disc's in VS11+ but still does not burn.
When burning via VS6 a plug-in window opens before burning. Do I have a plug-in missing for VS11+?
Sorry this is a bit long winded but any help would be appreciated.
Regards
David
Post by BrianCee »
Do you receive any sort of error message David - are you selecting the double layer disc option and could you explain a bit more about what happens when you click the 'Burn' button in the DVD creation window.
ibbotson
Post by ibbotson »
Hi Brian
Yes I am selecting the double layer 8.5.
The burn process is as follows
Total Progress-Prepare output content
_______________________________100%
Detailed Progress-Video/Audio Muliplexing
Then
Total Progress- Prepare output content
Detailed Progress-Finalizing VOB
All the above process completes Ok I then get the following error message
Ulead Videostudio failed to burn data onto disc [534:-2147216291:0]
I can go through the burn process if I burn via create DVD folders. I also tried a very sort film and it burned OK to a 4.7 disc so not sure what the problem is regarding the 8.5's
Regards
Chromenut
motherboard: Lenovo ThinkPad Edge E520
processor: Intel i5 2410M 2.3GHz
ram: 4gb
Hard_Drive_Capacity: 750gig
Post by Chromenut »
Just out of curiosity, have you updated to the latest DirectX?
...if I only had a brain...
Post by Black Lab »
And we can assume your burner is rated for double layer discs? :wink:
ibbotson
Post by ibbotson »
Hi all
Yes my burner is OK for double layer. No I have not updated directX so will give that a try.
