Video Filters Unavailable?
babyleon
motherboard: PEGATRON CORPORATION 2A86 1.04E01
processor: Intel Core i7 930 2.8GHz
ram: 12.0GB
Video Card: ATI Radeon HD 5450
Hard_Drive_Capacity: 7+ TB
Post by babyleon »
Started VS11.5+ and in the edit function, when I click on Attributes, no video filters are available. The .dat files still exist in the application data folder.... Did I do something to make them go away???? Any ideas on how to make them available again?
Thanks.
Post by Black Lab »
You can find the answer in the FAQs forum, or by doing a Search.
http://forum.corel.com/EN/viewtopic.php?t=17854
The fourth post, from TDK1044, is the easiest solution.
Nobody knows why it happens, but it's a problem VS has had for several versions.
babyleon
ram: 12.0GB
Re: Video Filters Unavailable? and new related problem
Post by babyleon »
I wasn't sure which of my previous posts to put this in....
I was able to fix my lack of filters problem as suggested - remove uvs.ini and re-start (but first copying my VS_Video.dat and similar library files to another drive first since they are otherwise overwritten with the basic .dat files). That worked fine and I was able to copy my .dat files back and have all my custom libraries again.
The other day my filters "disappeared" again so I went through the same process. I got my filters back but when I copy my custom .dat files back into the appropriate folder and re-start VS, only the default libraries are there. I still have copies of my custom library files from this time as well as from the previous similar event. It seems VS is just not recognizing them. Any suggestions?
Thanks.
Wayne
Accolades
motherboard: Gigabyte GA-EX58-UD4
processor: QuadCore Intel Core i7 920 2833 MHz 21 x 135
ram: 12 GB DDR3
Video Card: Nvidia GeForce GTX 295
sound_card: On Board 5.1 Surround - Realtek ALC888 - 1200
Hard_Drive_Capacity: 4TB +
Post by Accolades »
Filling out your details in the User Control Panel would hel others with future problem solving. :?
My You Tube Channel:
My Vimeo Channel:
SONY MOVIE STUDIO PLATINUM HD 10, Corel Video Studio X3, Corel Draw Graphics Suite X4 (Draw, Paint), Adobe Photo Shop CS4, Adobe Bridge CS4, DivX 8, Irfranview, FRAPS, Deamon Tools, VLC, MyDefrag, Nero, AVG, Winamp, Autopano, VMware...
babyleon
ram: 12.0GB
Post by babyleon »
Sorry about the Profile. I guess things have changed since I last put that info in. I don't think it has much to do with my present problem though. I have added no hardware or software since I was able to access my custom libraries.
I have tred replacing the uvs.ini several time now and returning my custom libraries to the ApplicationData\etc.\etc. folder, But i am still only getting the basic libraries showing up.
Should I try reloading VS11.5+?
Any other ideas?
babyleon
ram: 12.0GB
Re: Video Filters Unavailable/Restoring Custom Libraries
Post by babyleon »
I was reading back through some of my other posts here and found that when I was having problems with burning DVDs:
http://forum.corel.com/EN/viewtopic.php?f=1&t=30655
In that problem, I coincidentally bumped into a similar problem of not getting my custom libraries to work after a re-install of VS. The way I finally got them to come back was to copy them into the appropriate ApplicationData folder then click on the .dat file itself to restart VS11.5+. When it re-started, my custom libraries were there. I had to do this for each custom library, one at a time, closing and re-starting VS each time. I had forgotten all about that.
So I tried that again just now. It did not work with my most recent set of .dat file copies. But when I went to the previous set of copies from about two weeks earlier and did the same thing, it worked!
It seems there must be a problem of some sort with my most recent copies. I will go with my next older set and will only lose about 5 hours of work instead of hundreds of hours of work over the past four years. I can live with that.
Once again, if this Forum was not here, I would have been screwed. Thanks again to the moderators for keeping it up!
Reason: Link changed to reflect the new address http://forum.corel.com/EN - using the old one causes a user to be logged out.
