Is it just me or is the text tool screwy in X3??
pdxrjt
- processor: Intel Core i7 - 4.2 GHz
- ram: 32 GB
- Video Card: NVIDIA GeForce GTX 1080
- Hard_Drive_Capacity: 10TB Int.
- Monitor/Display Make & Model: Acer 32 inch x2
- Corel programs: Paint Shop Pro 2018
Well, to add my snippy two cents (again!!)
, I think Corel could make a few more improvements.... how hard could integrated panoramas be??? I do find, in general, X3 more buggy than X2.... for example, every now and then, maybe once every 4-5 times, X3 won't open. Starts up, I get the tool bars on the right monitor and the main screen is a big blank white spot. I've let it sit like that for about 5 minutes just to see if it was slow loading. Nope, wasn't going to open. Yet after I shut it down with task manager, it opens great the next 4-5 times.... I don't recall that ever happening with X2. Ah well..........
marty2010
- motherboard: Gigabyte Z68A-D3H-B3
- processor: Intel Core i7 2600k
- Video Card: NVIDIA GeForce GTX 550 Ti 1GB 8.17.12.8026
- sound_card: Realtek
- Hard_Drive_Capacity: 2TB
- Monitor/Display Make & Model: Viewsonic , VX2250WM-LED, 2 each
pdxrjt
- ram: 32 GB
Yes, I messed with it (but didn't return to the help file.) So, I put in some text and hit apply...... fine.... resize and move around. Add some more text....hit apply fine. Double click on the second text and I can again, resize and move it..... but "apply" is non-functional. Also, if I double click on text #1, nothing happens..... "apply" is non-functional, and it does not let me resize or move it. Oddly, in both cases (resize-moving text 2 or just double clicking on text #1) I cannot "apply" it. However, when I go to close the image, it says I must apply or cancel the text operation. Hmmmmmm.
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
marty2010
Ok I see what you mean.
Line 1:
Text tool, text, apply button, move, resize, "A".
Line2:
To edit any line of text. Program will select last line entered for resize/edit.
If you want another line double click it instead.
I select Text tool, double click the line I want, type any character in the text line and backspace over it.
Then Apply, resize then "A".
If I have double clicked the wrong line you can use the Cancel Button.
Again another line to edit.
In the case of a double click (selection) to edit text I type any character in the text line and backspace over it. Then Apply, resize then "A".
Edit:
Also to modify a everything in a line:
Double click the line you want, drag cursor to highlight the whole line and change Font/Size/Stroke-Fill Colors, etc. in Tool Options, Apply, then, A.
All text edits ultimately end with the "A" key (Pan Tool).
Line 1:
Line2:
Edit:
Best Regards,
Vaughan Martell
Vaughan Martell
