Source Files
PAL HDMV
Type: H.264 Video Upper Field First
Attributes: 24bits, 1440 x 1080, 16:9
Frame: 25
Date Rate: Variable (Max 12000)
Using the Share option and then, Create video file, AVCHD > PAL HD 1440
The file is created fine, its only a small 2 min test file with 4 Crossfade Transitions, but these are very blocky between scene fades.
When I select the PAL HD 1440 the Mpeg Optimizer pops up showing the Green segments for the original files, then the red parts from the transition area's.
Any suggestions? If I encode the file to plain DVD Mpeg the transitions are smooth.
X3 AVCHD crossfade blocky
meinthecorner
- motherboard: Asus P9X79 LE
- processor: Intel Core i7-4930K 3.4GHz
- Video Card: Nvidia Gforce GTX650
- sound_card: on board
- Hard_Drive_Capacity: 4TB 2x2TB
- Monitor/Display Make & Model: LG \ HP
I've seen this problem. It is due to the low quality and data rate the transitions are encoded. Cross fades are particularity tricky to encode.
Not using Smartrender may help if you up the quality settings to maximum.
Also under File-Preferences-Edit make sure Resampling quality is set to Best.
Regards
Phil
Regards
Phil
meinthecorner
The only reliable way around it is to render out as something else. For example I'm just rendering out a project in a lossless format which means transitions are created without any compression artefacts then use a third party encoder to get DVD and AVCHD out. Cross fades are then just perfect although it all takes much longer.
The main issue I think is the AVCHD compression settings in VS seem to have a low average bitrate which you can't seem to change and this low average effects any complicated scenes needing re-encoding, including crossfades.
Regards
Phil
Regards
Phil
meinthecorner
The lossless format is http://lags.leetcode.net/codec.html. You could try rendering out using this format (you select Share->Customer->Microsoft AVI->Set the Field order and resolution correctly, then on the Compression page select the Lagarith Video Codec.
File sizes are big but you can use this file in any third party encoder to compress down to your target format.
Regards
Phil
Regards
Phil
