PSPPX3 Scripting in Alpha?
OldRadioGuy
motherboard: Dell 0YJPT1 A00
processor: Intel Core i7-3770 3.40 GHZ 8 virtual cores
ram: 16 GB
Video Card: AMD Radeon HD 7770
sound_card: Realtec High Definition Audio
Hard_Drive_Capacity: 2 TB
Monitor/Display Make & Model: Samsung 23" HD 1920x1080 px
Post by OldRadioGuy »
Does anyone use scripting in PaintShop Photo Pro X3?
I recorded a sample script, opened it in the script editor and found it is still in "Alpha."
Affinity Photo 1.5 | ON1 Photo RAW 2017 | DxO Optics Pro 11 | Aftershot Pro 3 | Olympus PEN-F cameras
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
I believe the scripting engine is still pretty much in the same shape it's always been. A few added commands to deal with any extras or changes made to PSP itself.
The text "alpha" may just be a forgetful moment on Corel's part. Like they were testing the scripting when PSP was still in its alpha form and labeled it as such then forgot to change the label.
But all of the scripts still work as expected. So if this is the Alpha, it's better than the full release of the program itself and I would love to see what they do with the language. But I don't think the scripting is in alpha. I think it was just a label they forgot to change.
Kazren
motherboard: acpix64-base PC
processor: Intel Core i7 CPU
ram: 8 GB
Video Card: NVida GeForce GTS 250
sound_card: Realtek High Definition Audo
Hard_Drive_Capacity: 1000 GB
Re: PSPPX3 Scripting in Alpha?
Post by Kazren »
Maybe someone can help me. I have both PSPX2 and I downloaded X3 because of this problem, but it still freezes up every time I try to run the script. It's a TJP scrip made for images all the same size. I need help.
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Post by Trev Bowden »
Could You give more details on this script full name and where i can down load it to see what the problem is.
As it ever worked?
ram: 6 GB
I don't want to assume but they might be referring to The Jazz Pixie's scripts for tags found at the bottom of the page here...
http://www.jstenning.me.uk/Scripts/TJP-Scripts.htm
I'm downloading it to see for myself but here's to hoping.
Kazren, can you turn on your script output palette to see if that provides any valuable information on what's happening while the script runs?
EDIT: Wow what a process. Okay I'll wait for Kazren to get back about the actual script used because if this is the script...the process is very long and complicated and any number of things could go wrong if it's not implemented properly.
Kazren
ram: 8 GB
Post by Kazren »
LeviFiction wrote:I don't want to assume but they might be referring to The Jazz Pixie's scripts for tags found at the bottom of the page here...
I've tried, with the Script output palette, but it never even gets that far - it simply causes the program to freeze up forever until I close it down.
I'm using Windows 7 64 bit. I have been using this same TJP scripting for years on the Vista and prior to that XP computer. I tried running pSPX2 in the "XP Mode" you can run inside a Virtual PC on Windows 7 - that didn't work, either.
ram: 6 GB
Well unless someone else comes up with a good answer for you soon I'll be over here seeing if i can't figure out at which point the script stops functioning.
