I have tried to capture, and can, but a window comes up saying" Flushing DV Transcode Buffer: then there are what looks like a count down of the ?? Buffer???
Yes, I am new, and will take ALL the HELP I can get.
buffer notice
THoff
jimw
Again thanks, but if you could take me through it a step at a time, I might be able to do what I need to!!! They(ULead) that I had to run in the mpeg2, out put to vds, and **---- Help againTHoff wrote:SEARCHING is your friend.
To sum things up, you are trying to capture in MPEG2 format, and your system isn't capable of performing the transcoding in realtime, filling up the buffer. So UVS is forced to stop the capture, finish the transcoding of the buffered data, and then resume.
rwindeyer
To sum it up quickly: DV format is (essentially but not quite) uncompressed video. Capturing to DV format just invloves a simple transfer of data from camera to hard drive - very little work for the computer to do.
What you find on a DVD is video in mpeg2 format - this is significantly compressed video. The question is - at what stage of the whole process do you want to do this conversion process? You are obviously doing it at the capture stage (OK, many people do this), but converting DV to mpeg2 "on the fly", or in real time, is incredibly demanding on the computer. It periodically has to say "hang on a minute, give me a chance to catch up".
I prefer to capture in DV format anyway - I think it's better for editing. I suggest you do that, do all your editing, and then let the computer chug away for hours transcoding the project into mpeg format.
jchunter
