Editing Original Audio Track
rckowal
Post by rckowal »
Somehow, I find myself with a clip that has two red lines in the original audio track. The level in one of them is adjustable but the other isn't.
As a result I'm hearing some of the audio from the non-adjustable red line. I want to completely silence the audio on that clip so only audio from the music track can be heard.
Can some please tell me how I got the two red lines? Additionally, how can I get rid of them?
Best regards, Richard
rckowal
Post by rckowal »
Since no one has replied to this post, I guess this forum must be broken. (grin)
Humor aside, with all of the knowledge presiding here, certainly some one knows the answer to this question. If so, please take a minute to reply.
You don't say what version of VS you are using -- though you may have in another of your threads. But are you sure that both lines are red? In my X2, for instance, the adjustable line is red but the other is green... And that simply shows the median line of 0dB as far as I am aware. It gives you a norm from which to be able to judge whether your audio edits are higher or lower in volume.
The mute the audio, left click and hold the end of the adjustable line and drag it to the bottom of the screen. Then do the same with the right hand end.
Or more simply, just use the Mute button to the immediate right of the audio controls in the approximate centre of the VS screen... Or adjust the volume control down from the default 100 to 0... :lol:
rckowal
Post by rckowal »
Hi Ken,
VS is 11.5 Plus which is very similar to X2.
Well, yes & no but that's what confuses me.
To clarify. In all but a small segment of the time line, one is red & the other is green. However, in the segment in question, there are two red lines. They only appear in a small gap in the video where some thing went astray during editing. This gap is between adjoining clips separated by a transition.
Does that give you what is needed to diagnose this condition?
But does the sound remain in that spot when you mute the whole clip?
In any case, I suspect that (or those) particular line(s) is/are the cross-fade of the audio from the two adjoining clips. But again, you should be able to pull the little blocks that appear at the far ends of the line down to the bottom...
Post by Black Lab »
So are you saying the mute button doesn't work?
rckowal
Post by rckowal »
Ken:
Yes, the sound remains in that spot even when the original audio & music tracks are both muted.
Additionally, you're right that this is isolated to a spot where there is a "fade to black" transition between two adjoining clips. I've tried pulling down the red lines. The lower one moves OK but the upper one (supposed to be green) doesn't.
Revised since posted: After experimenting a bit, I found that this was apparently caused by an overlooked problem between adjoining clips. It was supposed to be "fade to black" followed by a color image to create a "black to off-white" transition - suggested by Trevor. The off-white part of it was missing - probably pilot error during editing. Once I replaced it, the audio problem went away.
Jeff:
No, the mute buttons work.
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Red line
Post by Ken Veal »
If this has anything to do with the preview range-
RED LINE -REMOVE- which removes the preview range
The red line represents the Preview Range and shows as a line in the
Ruler Panel below the Preview Window.
This allows you to play only part of a project.
If a mark in/out point is selected in the Project mode you will only be able to see
the video inbetween those points.
To remove the red line, (which was inserted whilst in the Project mode by setting the in or out points)----move the black triangle(trim handle) below the
blue bar at the bottom of the Preview Window that is on the left to the start
of your project .
Then click on [ or F3.
Move the trim handle(black triangle) on the right all the way to the end of your Project and click] or F4.All this must be done in the PROJECT mode.
The above method is one way of trimming a clip in the CLIP mode.....
Ken
rckowal
Post by rckowal »
Hi Ken,
Thanks for replying.
The red line represents the Preview Range and shows as a line in the Ruler Panel below the Preview Window.
I'm familiar with the workings of the Preview Range ruler panel. My issue is not with that red line. It's in the original audio track which is a sub-part of the original video track.
There is only ONE red line, not two - perhaps you have overlapping audio clips.
