GIF/WaterMark Problem....
mikeyek1106
Post by mikeyek1106 »
Ive only just started using Corel and have stumbled across a small problem which im not entirely sure i can rectify.
Im trying to add a gif with a 'transparent' background as a type of watermark to some short WMV files, but when i add them to the video as an overlayed track, the appear to become like a negative rather that how they when viewed normally.
I can get it running fine using the image as a jpeg but it looks awful as it retains a white background.
Can what im looking for be done?
TIA. :D
Welcome to the forums,
GIF files can be somewhat problematic when used in VS. For instance if you try using an animated GIF, inserting it as an image, will only provide the first frame.
JPEG images are 24-bit images, and do not contain the extra 8-bits for the alpha (transparency) channel. Use the PNG, TIF, or TGA for your watermark, as they support transparency. The more common being PNG.
mikeyek1106
Ron P. wrote:Welcome to the forums,
Thanks for the speedy reply.
Its not an animated gif, im wanting to walk before i can run. :D
Will have a look into those other extensions and let you know how i get on.
Thanks.
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
Thanks.
If you put a color background to the gif then saved it as a jpeg, you could import that to an overlay track and use Chroma key to make the background transparent. Choose a very bright pink or similar for the background making sure this color does not appear in the gif image otherwise you will make that part transparent too. When using the Chroma key choose "0" as the similarity value!
John Mitchell
mikeyek1106
Thanks for the help guys.
Mitchell, spot on mate, worked a treat. 8)
mitchell65
ram: 4Gb
Thanks for the feedback :)
John Mitchell
