Just wanted to share in case you run in to it.
Steps to reproduce:
1) Set your background stroke color to disabled
2) Create a new image, open any existing image (doesn't matter)
3) Select the Text Tool
It crashes every single time.
I have found it does not crash as long as you have the background stroke color set to not disabled, or if you have an image open that you have already used the Text Tool on. Even if you set yout background stroke to disabled, it will be fine if you have already used the Text Tool in that session.
I have also noticed that X3 has a problem with gif optimization. If you're trying to optimize an image that already has a reduced color pallette, the file's pallette it saves gets completely screwed up. This never happened in X2.
You have to first increase the color pallette on the image, and THEN you can run the gif optimizer with out corruption.
So far I have been less then impressed with X3. It seems to offer nothing substantial over X2 (aside from Express Lab and Project Creator, which I will never ever use), and the install size ballooned from 380mb to 1.37gb. Am I missing some substantial feature upgrade besides the silly Express Lab and Project Creator?
I'm glad there is a try before you buy, as this is looking like a skip-me version.
