'Mismatch file format'.
I have installed flash player 10 active x, but its still not working.
Also, when i batch convert my VSP files into Flash file (.flv format) it stop responding and eventually close.
Please help.
Well what is in your VSP files? VSP is a VideoStudio Project file, that is like a text file, having a bunch of instructions, like what source video, image, audio files are being used, where they are located on your computer, and what editing you want done to them. Could you provide us with more information? A guide as to what info we need can be found in the following thread:Also, when i batch convert my VSP files into Flash file (.flv format) it stop responding and eventually close.
Yes John you can batch convert VSP files, and it works very well especially if you have multiple VSP files to convert.mitchell65 wrote:Hi Alnish
I'm not sure why you are trying to batch convert vsp files. If you are trying to save a single vsp to flv format, then go to Share > Create video file. I don't think you can batch convert vsp files because as Ron says they are basically text files not video files.
Hi AlnishAlnish wrote:Thank you both of you guys and special thanks to Ron. I have sorted out my problem by adding flash.ocx file in system files. My .swf files are working fine in VS now.
My VSP files which I want to convert it into Flash files (*.flv) contains the following items :
1. Flash file (*.swf)
2. One Video File in .wmv format
3. Two Audio Files in .wav format
4. Few Jpeg Images
5. Transitions.
Alnish
