Split screen effect - get rid of the black line (join)
Darryl
motherboard: ASUSTeK
processor: 2.00 gigahertz Intel Pentium Dual
ram: 2GB
Hard_Drive_Capacity: 1312.14 GB
Monitor/Display Make & Model: Acer AL1515
Post by Darryl »
deleted
Samsung SC MX10, Canon OpturaXi, VS X2
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
Hi Darryl
Apparantly it is not unusual to find that the two clips are a slightly different shade. Using the brighness filter should overcome this problem.
John Mitchell
Darryl
ram: 2GB
Post by Darryl »
Wow!! Brightness filter, that's the ticket. There was such a huge difference I would have thought nothing could overcome it. The split is seamless. Thanks a lot.
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
Post by aljimenez »
This has been such an enjoyable thread I want to say thanks. What you are doing is very neat, and learning how to do it correctly by your experience and all the neat tricks in VS that have been suggested has been great... Al
User for more than 10 years.
allanforbes
processor: Intel Core i7cpu Q720 1.6GHz 6 MB L2 L3 Cache
ram: 4GB
Video Card: Nvidia Geforce Cuda GT330M
sound_card: Nvidia
Hard_Drive_Capacity: 500GB
Monitor/Display Make & Model: 41.6 cm (16.4") VAIO Display Premium HD1080
Post by allanforbes »
Darryl wrote:I did not solve the original black line problem. I had been working at trial and error to achieve what allanforbes is trying to do and the blplhp tutorial clarified the process for me. The only difference is I do not think "Fill Color" in the cropping filter should be ticked. If you are referring to how I solved my background color problem, haven't solved that one either, could be just be an uneven lighting problem or (most likely) could be that I forgot and left one of the fill color boxes ticked, in the cropping filter. My original test taping has been moved and edited and re edited so much I do not know what is what so I am going to start all over from scratch. Although I do not know allanforbes exact method I am hoping that by following the blplhp tutorial and unticking fill color box, in both frames, and then aligning left and right frames in the preview window will solve both our problems. I'll let you know.
If you dont use fill colour - what colour do you use to apply chromakey? - I used bright pink as nothing in shot is pink!
mitchell65
ram: 4Gb
Hi Allan
I have just created a project with two clips in HD. I set the crop to 52% wide and 100% high. Like you i used bright pink and set the Similarity to "0"
Without I physically move them apart I cannot replicate the black line.
John Mitchell
mitchell65
ram: 4Gb
Have just created another project same as first but 50% width. On You Tube this one shows the black line! If you want to see them both they are here:
This one is 52% width title "split screen":
http://www.youtube.com/user/mitchellbon ... R6A7bLi1Bs
And this one is 50% width title "split screen 2":
http://www.youtube.com/user/mitchellbon ... 0POqCJ4izU
We will succeed with this, I'm sure :wink:
John Mitchell
Darryl
ram: 2GB
Post by Darryl »
deleted
mitchell65
ram: 4Gb
I do not use chroma key, I can't seem to get it all keyed out, properly. I think I must be missing something in the process.
try setting the similarity to "0"
John Mitchell
allanforbes
ram: 4GB
sound_card: Nvidia
Many Thanks
Darryl wrote:Hi Allan, I do not use chroma key, I can't seem to get it all keyed out, properly. I think I must be missing something in the process. What I do is..... I take the clip I want for the left side and put it in an overlay track and set it to fill screen. Apply the cropping filter. Adjust the portion you want cropped. Untick "fill color" and tick "stationary". Click first key frame and copy. Click last key frame and paste then "ok". You will see a distorted view in the preview screen, do not worry. Next drag the clip you want for the right side to the main video track. There is no need to crop this clip, but you may, if you find a need to. Next click on "clip", under the preview window. Drag the line, for the overlay track, to the left until it lines up the way you want it to look. That should be about it.
Hi Darryl, Your last post has solved my black line problem - the method that you described works much better than the tutorial which I had been following that suggested using fill colour and chromakay. Many thanks.
Darryl
ram: 2GB
Post by Darryl »
Glad to hear it worked for you.
