I have 500 images Maya animation exported in TGA, 30fps. It should last for 20 seconds, but when imported to MS Pro I get it around 16 seconds, how do I extend it to what its supposed to be - 20 second.
Newbie here in MediaStudio pro so please use step by step explanation.thanks
Maybe I should also ask, why does MS Pro shrinks time duration when it should be 20 sec.
How to extend ?
MonroePoteet
You *can* use "Speed" to extend it
As the previous post says, 500 / 30fps = 16.67 seconds. If you really want 20 seconds, you can either render 600 frames or use right-click on the imported image sequence in the Timeline, select "Speed" and specify the new duration as 20 seconds. It'll stretch the material you have by duplicating frames as necessary. Better to render 600 frames.
mTp
mTp
