Chapter Entry Frames?
Mike Hart
Post by Mike Hart »
Howdy,
When rendering a disc image in VS8.01, I get the message "Some chapter entry frame numbers exceed the total frames". I click "OK" and it continues to render.
What's that mean? There are only 11 chapters and 100's of thousands of frames.
After using the auto feature to create chapters, based on scene clips, I created in the edit module, I removed a few of the chapters. Could that be the cause of this condition?
If it's a problem how do I fix it?
If it's not a problem why does VS8 give this alert?
Thanks,
Mike Hart
P4, 2.2 ghz, 1-gig RAM, XP pro, Nvidia GeForce FX 5800, VS8.01
kebrinton
Post by kebrinton »
I think I worked this out once. I think it means, for example, that your last clip might be "clip 55," but you only have 50 clips because you've got rid of some. That's what you said. Being told something you already know makes you wonder if something's wrong.
Now somebody with more experience can give us the real reason.
