editing picture tubes
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
How do you move and rotate picture tubes in PSPro x.The learning centre tells me to resize via the scale slider in the tool options pallette but I cant locate that............Ken
df
ram: 64gb
Hard_Drive_Capacity: 1 Tb
Post by df »
There is no move or rotate feature, but if you place the picture tube images on a sepearate layer you can manipulate things better from there.
Size (scale) should be on the tool options pallete. Press F4 a few times when you have to picture tube active and you should see it appear and disappear a few times.
Ken Veal
ram: 32 GB
edit tubes
Post by Ken Veal »
Thanks for that. .....How do I place one on a separate layer.Dissapointed to learn they cant be moved , rotated or resized easily .The reason for asking was that ,eg the glass of beer shows at all different angles as well as upright and the only way I could find to get an upright image was to undo and keep clicking until a tube displays that was the correct colour and upright.
Another issue is that when I select a tube another one shows, like selecting the hat and a lap top shows.
Sometimes after using a particular tool the pic tube icon does not show, is this normal. ..................Ken
df
ram: 64gb
Post by df »
Find the folder that your picture tubes are located, then open the picture tube file that you you need. Use the lasso or something to select the image that you want, copy and paste as new image. Rotate to where you want it, save it somewhere that you can grab quickly.
Picture Tubes to me are meant to just be random and fun. The only things that I know of that stay the same orientation are the fence and flames, but there could be more.
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Post by Trev Bowden »
I find the easy way is to open a second image paint some tubes select the one you want then copy pate in to your main image as a new layer then you can use the pick/deform tool in the normal way
