X2 - Creating MOV file with Stereo Sound
Clevo
motherboard: Asus PK5
ram: 4GB
Hard_Drive_Capacity: 850GB
Post by Clevo »
Hello All,
I helped a friend make a short video to enter in a Film Festival. They wanted it in MOV format at high quality settings. I figured they were going to use an Apple laptop to play through a projector. I made inquiries and that's exactly what they are going to do.
I also had to maintain 16:9 Aspect Ratio so when converting from SD DV-AVI format getting the pixel dimensions was crucial. I had no problems here by going to:
Create Video File/Custom - selecting quicktime, adjusting the pixel domensions.
However, when trying to customise the Sound properties, X2 would crash.
I tried this several times with the same crash problems. So I am stuck with a nice video with a horrible sounding mono sound.
Other than creating a template (which I thought of well after I delivered the DVD (data file)). Does anyone know how else I could have resolved this?
Post by Black Lab »
Could you use an audio editor for the sound, then import into VS?
Post by Trevor Andrew »
Hi Clevo
What settings are you trying to use for your mov custom template.?
There are many compression types to choose from.
I have used X2 with no problems in creating several custom options similar to:-
QuickTime Movie Files
24 bits, 1280 x 720, 30 fps
Frame-based
Photo - JPEG
None, 8.000 KHz, 16 bits, Stereo
I am a little unsure as what audio compressor to use so left it as None.
My program never crashed during these tests.
I own a Panasonic TZ5 that uses Mov files, I will check the properties of these when I get back to my desktop pc.
Hi Clevo
As your video is Dv-Avi, I created settings to DV-Pal
Frame-based
DV - PAL
again no crashes.
I haven't use any settings to render so cannot comment on quality........
Kingston
motherboard: Gateway [Acer] DX4860
processor: Intel Core i5 3rd gen. 3 GHz
ram: 8 GB
Video Card: Intel HD 2500
sound_card: Bluetooth
Hard_Drive_Capacity: 1 TB
Monitor/Display Make & Model: Dell ST2210; Samsung SmartTV 3D 40"
Post by Kingston »
I was trying out Quicktime format in VideoStudio X3 and also in another app and when I tried to modify the audio settings there was a crash. That was with Quicktime version 7.6.5.
I uninstalled 7.6.5, rebooted, then installed 7.6.2 and rebooted. That fixed the problem for me.
A similar problem occurred to me when updating from VS 9 to VS10,
I am running QuickTime 7.0.3
Clevo
ram: 4GB
Post by Clevo »
So it seems the solution is to go for the lower version of quicktime....
... or at least don't upgrade from the version installed with that version of VS...
Clevo
ram: 4GB
Post by Clevo »
Installing an older version of Quicktime does indeed solve my issue but it creates another.
iTunes requires at least quicktime v 7.6.4 to work. I installed v 7.0.3 which fixed my problem but created the issue with iTunes & Vista Aero
Hi Clevo
I mentioned I had similar problems with VS 9 to 10.
Eventually I did install the latest QT and found it worked ok, this was with my old XP system.
I don¡¦t know what files if any the older versions change, its just strange.
Maybe manually updating to the latest rather than the auto update is the way to go, a little like the Direct x update.
