DVD MovieFactory 6 Unspecified Error Issues
earnolmartin
I really liked the results I was getting with DVD MovieFactory 6 in the past, but now I've been having all sorts of issues with it. My computer is running Windows XP x64 SP2 with the latest .net framework, Visual C++ Redistributable, and the latest DirectX 9. I'm running a Core i7 920 with 9GB of RAM.
So, I wanted to rewatch all those Buzz Lightyear cartoons I loved as a kid, but when trying to burn the disc, I receive the error of "Unspecified Error", and I cannot burn my creation or even output it to a disc image.
When finalizing my DVD, it goes through these steps before the error message.
Convert menu
Building motion background of the menu page
Preparing Output
Unspecified Error
This error message gives me no additional information, and Corel support has been unable to fix this issue. I've identified that my video clips use the X-Vid Codec. So I installed the X-Vid codec from their website, and I installed K-Lite Full Codec Pack making sure to have it not interfere with the official codec from X-Vid. Needless to say, I don't think it's a codec issue, as it converted the video before it tried to build the menus.
I resaved my background image as a .bmp since I had seen users report errors with specific JPGs. I removed all the fancy transitions and stuff from the menu, but that didn't work.
You can view actual screenshots here:
http://www.dinofly.com/images/ulead_issues.jpg
Convert menu
Preparing Output
Unspecified Error
Wim Kok
- processor: AMD FXtm-4100 Quad-Core
- ram: 8 GB
- Video Card: NVIDIA GT 520
- sound_card: Realtek AC97
- Hard_Drive_Capacity: C640 D500
- Monitor/Display Make & Model: Acer AL1951 LCD
Re: DVD MovieFactory 6 Unspecified Error Issues
I had the same message which, in my case, was caused by overlapping elements in the menu's.When finalizing my DVD, it goes through these steps before the error message.
earnolmartin
How do I make sure items are not overlapping? Ulead tells me that some items are overlapping on the menu, but I didn't think it would be that big of a deal. It doesn't look like anything is overlapping, but Ulead thinks it does.Wim Kok wrote:I had the same message which, in my case, was caused by overlapping elements in the menu's.When finalizing my DVD, it goes through these steps before the error message.
Wim Kok
- ram: 8 GB
Obviously you did not get the warning for overlapping items in your menu when you switched from step 2 to 3 (the burning screen). Look to the thread of jan 6th "Warning for overlapping did not pop up." Going, in step 2 (Menu & Preview) to "custom" will certainly show the overlapping area's. Big chance DMF will function, but don't forget to restore the first warning as Ron advised me. W.K.
Wim Kok
- ram: 8 GB
And did you manage to get DMF do the job?How do I make sure items are not overlapping?
regards
Error Message
Yes I had exactly the same problem and it was caused by overlapping menu
Why not try burning a disc of this film ( On to a DVD-RW ) with just a very plane menu and see if it will burn If it dose it is a problem with the menu this is how I found why my would not burn
Regards
Chris
Regards
Chris
Wim Kok
- ram: 8 GB
Hi Ron,Ron P. wrote:When you're speaking of overlapping menus are referring to the buttons used to select the titles or what?
especially titles can cause this problem. In case I've a complex menu and with titles I check from now on, since my last experience, through the tab Edit>>>Customize. If anything is wrong you'll see it immediately here.
regards, Wim Kok
