.8bf files??
pdxrjt
processor: Intel Core i7 - 4.2 GHz
ram: 32 GB
Video Card: NVIDIA GeForce GTX 1080
Hard_Drive_Capacity: 10TB Int.
Monitor/Display Make & Model: Acer 32 inch x2
Corel programs: Paint Shop Pro 2018
.8bf files??
Post by pdxrjt »
Well this always happens.....I do a lot of photography, but the release of a new version of PSP leads me to learn, explore and upgrade the extras of the new version. Soooo, what are 8bf files....I have some in a folder labeled PSP Extras (my name) where I have stored various masks, frames etc. What the heck are 8bfs though???
motherboard: Alienware M17xR4
ram: 6 GB
Hard_Drive_Capacity: 500GB
Corel programs: PSP: 8-2023
Post by LeviFiction »
*.8bf is usually an Adobe Plugin. For example my 2DHyperClouds plugin is labeled 2DHyperClouds.8bf
So if I'm correct those are plugins for extra functionality in Paint Shop Pro.
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
To use them in X3, go to File > Preferences > File Locations > Plug-ins and add that folders location.
Tim Morrison
C-Tech Volunteer
pdxrjt
ram: 32 GB
Post by pdxrjt »
Gracias....and they show up!!
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
8B files
Post by Ken Veal »
I referred 8B files in
http://forum.corel.com/EN/viewtopic.php?t=37180
which was posted because I am unable to see a Ulead Particle plug in in PSPro X after downloading it.
In the file locations box I said"limit loaded plug ins to those with an .8B? extn only" was ticked.
(I unticked this box but plug ins were still greyed out under effects so I ticked the box- should this be enabled or not).
Now know too what these are but it not helped me with this problem………..Ken
pdxrjt
ram: 32 GB
Post by pdxrjt »
Seeing all the plug-ins I put in there..... having trouble seeing all of the brushes I recently downloaded.... even though they are supposed to be PSP... but that is another thread!! (no not the PS brushes I downloaded, I figured that out.)
prazim
Post by prazim »
Ken,
Older, incompatible plugins will not show up in PSP until you "convert" them. The tool I use for this is called Plugin Commander Light. There is also a pro version with many additional features.
http://thepluginsite.com/products/picopro/index.htm
Cheers!
marty2010
motherboard: Gigabyte Z68A-D3H-B3
processor: Intel Core i7 2600k
Video Card: NVIDIA GeForce GTX 550 Ti 1GB 8.17.12.8026
sound_card: Realtek
Hard_Drive_Capacity: 2TB
Monitor/Display Make & Model: Viewsonic , VX2250WM-LED, 2 each
Post by marty2010 »
I put the Particle.8bf here:
C:\Corel-PSPPX3\Corel PaintShop Photo Pro\X3\PSPClassic\Languages\EN\Plugins
Should this folder be reserved for only the .8bf types?
I ask because one option box in file locations (to check or uncheck) says:
Limit loaded plug-in files to those with an .8b? extension only.
Why is there this choice?
I initially thought all plugins for Corel should go here?
Also a question on a folder called "plugin", located here:
C:\Corel-PSPPX3\Corel PaintShop Photo Pro\X3\plugin
Is this folder supposed to hold any type of downloaded Plugins?
I see one dll file in the folder.
ulkFMgx.dll
Is this dll actually a plugin?
Inspecting the file I see:
File description: Multiple Keyframe controls support module
Product name: Unlead PhotoImpact
Best Regards,
Vaughan Martell
ram: 6 GB
.8b?
Replace the ? with another letter (traditionally an f 8bf) and that's the traditional ending for most photoshop compatible plugins. However plugins can also have just the regular .dll extension. The option to limit plugins that Paint Shop Pro loads is to make sure any plugins loaded have this extension.
I have no such folder and it's not labeled in my File Locations for PSP so..I have no idea what that thing is about. It definitely doesn't seem like something PSP does.
And plugin commander only converts plugins made with Filter Factory. Regular plugins are not effected by this. And unless plugins have been improved since version X Ken should have no troubles running the Ulead Plugins on version X so long as PSP points to them. I ran them just fine without any conversions.
marty2010
sound_card: Realtek
Post by marty2010 »
Thanks for the reply.
Can PSPX3 use plugins that do not have a 8bf extension?
Like some DLL plugins?
Also, like I mentioned:
ulkFMgx.dll is used by Product name: Unlead PhotoImpact.
I only installed PSPX3 and Corel Painter.
So it is a bit of a mystery how a PhotoImpact file got in this "plugin" folder:
C:\Corel-PSPPX3\Corel PaintShop Photo Pro\X3\plugin ?
Best Regards,
Vaughan Martell
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Post by Trev Bowden »
As far as photo impact is concerned Corel own them too so they may have used something from there More likely Uled bits are the movie bits or parts for Project creator. And No it can only use 8bf compatible not Even 8bi which are file format plug in
