Hooterville wrote:Can this thing be uninstalled by it's self?
I'm thinking about getting rid of this mess myself.
The download doesn't give you the option to install just PSP X3 without the Project Creator. The disk (boxed version) does. I don't know about uninstalling, but you can install just X3 without that. It also lets you install Painter Essentials Photo 4 seperately, but that's true with the download as well.
Yea, I have the boxed version but I installed this mess already.
I see no way to uninstall it by it's self.
I would have to uninstall and reinstall the whole program.
JimmyB7 wrote:Thank you for contacting Corel Customer Support Services.
You can troubleshoot this by your program's cache files. To do this, please following the steps below:
1. Close Corel PaintShop Photo Project Creator.
2. Launch Window Task Manager; to open Windows Task Manager, right-click an empty space on the taskbar, and then click Task Manager.
3. In the Windows Task Manager, go to Processes tab.
4. In the Processes tab, make sure that the following Processes are not running on your computer:
5. If any of the above are still running on your system, right-click on each Processes and select End Process or End Process Tree.
6. After making sure that the above processes are no longer running, go to taskbar and click on START >> RUN;
7. In the RUN window, type: %appdata%
8. Hit the enter key to open the Application Data folder.
9. Double-click on Corel folder and then double-click on Digital Studio folder.
10. Delete all the files and folders inside this "Digital Studio" folder.
11. Close this folder and re-launch PaintShop Photo Project Creator.
Should you have further assistance, do not hesitate to contact us again.
Nelson
I have tried this procedure and still cannot open anything else than the top level of "My Computer" and the "Deskboard". None of my files is aviable for treatment in Project Creator.
Regards Truls Nygaard
I tried my PaintShop Photo Project Creator after a few days of successfully using the procedure from Corel support. It again failed to list the photos, etc.
I once more deleted the files in Corel Digital Studio folder. Again this worked. But there definitely appears to be a bug that is causing the files in the Digital Studio folder to become corrupt.
JimmyB7 wrote:I tried my PaintShop Photo Project Creator after a few days of successfully using the procedure from Corel support. It again failed to list the photos, etc.
Hopefully they will fix this in a future patch.
Did you actually find the Project Creator worth working with? Seems pretty limited to me.
Well, contacted Support regarding this, they're totally clueless, other than the standard form response, they suggested I create a new user with admin rights (I have admin rights) and reinstall. Did what they asked and SSDD, so unless I call them, they'll close the ticket as solved.
I can't be the only one having this issue. I'm in Tech Support myself and this is pretty lame..
My pictures "disappeared" as far as PaintShop Creator was concerned. I followed the directions of turning off the processes. The key for my Vista operating system was deleting the two files "Blacklist" and "MLE_GOLDEN_GATE" in the Digital Studio folder. These are corrupt and must be deleted so the software can once again grind away indexing your photos. Do not stop it while it is doing it. For me this is why it went corrupt. I wanted the hard drive trashing to stop and plugged the plugged. Oh well.
I don't know why Corel created such a process. I see no benefit. The photo list display is so I can drag them into the bottom tray. This a real dog in terms of speed. I have around 130 photos and just displaying them is very painful. It only actually displays a screen page or two. The other photos are icon place holders that you have to wait for the software to update once you page down to them. Other applications I use including Corel's Photo Album 7 run circles around this software in terms of speed. I think for projects I've tried, I really still prefer Album 7 over Photo Project Creator. I agree with other comments. I wouldn't worry too much if you can't get it to work. Unless this is the only software you have, you most likely won't use it.
