Burn Failed - DVD Movie Factory 2010
BigDadBuddha
Keep getting "Burned Failed" message when trying to burn DVD. It goes through the whole process(converting and burning) and at the very, very end...Burn Failed( no other error messages). All clips are in MPEG DVD NTSC format. I have burned to folder and played back on WinDVD and all looks and sounds fine. Tried a few different brand DVD-R discs and same prob with all. DVD Burner seems to be working fine as I can burn Data discs with no problem. Any Ideas?
Sometimes there can be a conflict with your existing burning software. (Although, I'd expect you to get an error when burning starts...)
I assume you are using another progam to burn your data discs? You should be able to use that software to copy the DVD folders onto an actual DVD. (Make sure to tell your software that you're burning a "video DVD".)
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
- ram: 2 GB
- sound_card: Intel GMA 950
Please view:
DVD Burning / Playback issues
sging2
- processor: Core[TM]2 Quad CPU 2.66GHz [4 CPUs] 3.5GHz
- Video Card: NVIDIA GeForce GTX 570 .
- Hard_Drive_Capacity: 8TB
- Monitor/Display Make & Model: Dell Ultrasharp U2312HM 23 IPS LED
Re: Burn Failed - DVD Movie Factory 2010
Hi All
I am getting the same problem with DVD Movie Factory 2010. Every disk I try gets Burn Failure even the projects that burnt ok last month, now got 5 new coasters. If I use DVD Movie Factory 7 SE they burn fine so it cant be the burner. Anyone got anything new on this problem.
Stephen
Stephen
[Windows 7™ Ultimate (6.0, Build 6002) Service Pack 2]- COMPUTER XPS720 H2C [Intel(R) Core(TM)2 Quad CPU @ 3.47GHz (4 CPUs), ~2.7GHz]-[8GB RAM]-[NVIDIA GeForce GTX 570] - 8TB HD
garrisop2001
- motherboard: Gigabyte M57SLI-S4
- processor: AMD Athlon II X4 620
- ram: DDR2 6 MB
- Video Card: NVIDIA GeForce 8500 GT
- sound_card: Realtek High Def Audio
- Hard_Drive_Capacity: 1 TB
I'm getting exactly the same message; I've only burned two coasters so far. Help!?
