Install and Activate VSX3
Please note that there are TWO versions of Corel programs available.
1. ESD - Electronic Software Download.
This is a version that you purchase either a full version or as an upgrade to a previous version. With this you are given a SERIAL NUMBER.
You do not also get an activation number. If you want to re-install it at a later date you enter that same SERIAL NUMBER.
2. TBYB - Try Before You Buy.
With this one you can use the software for up to 30 days without having purchased it. If you decide to keep it then the trial version has to be ACTIVATED. The following steps will guide you through this process.
Firstly download the Try Before You Buy from this link.
It will ask you where you want to save the files and then you will see:
When you see this screen,
the program has paused awaiting user input. If like me you like to extract your set up files into their component parts, rather than using the single rather large setup file, you can now create a new directory on your hard drive, then copy/paste all of the (temporarily) extracted files to your new directory.
If you do not do so now you will not get another chance because at the end of the installation, the temporary directory gets deleted.
If you want to install VideoStudio from these setup files, the one you have to click is highlighted here:
During the installation process you will be asked to complete this screen.
You will get a thank you message to acknowledge that you have successfully completed the above.
After using the program you will be reminded of how many days are left of your free trial and you will be invited to purchase the product. If you choose to do so you will receive a Serial number from Corel after completing your purchase.
If you have a serial number or an activation number (explained below) then you should click the button at the bottom left of that screen.
If this is the first time you have ever installed the program then you will have a SERIAL NUMBER.
The SERIAL NUMBER is in this format VS13ABC-ABCDEFG-ABCDEFG-ABCDEFG
It is entered into the box at the top of the screen. You then activate it by clicking the [CONNECT] button.
If you do not have an internet connection then you should click the [Phone Corel] button where a member of Customer Services will guide you through the next stages.
If you have previously installed the program and you are installing it again for some reason - perhaps you have reformatted your hard drive and re-installed Microsoft Windows. You will by now have an ACTIVATION KEY
An ACTIVATION KEY is in this format 3ABC-4ABC-5ABC-6ABC you enter an ACTIVATION KEY into the box at the bottom right of the screen.
When you enter a SERIAL NUMBER you will see the following screen:
When you save the text file it will contain your new Activation Key.
centurion3
Delayed write failure
Post by centurion3 »
Steve,
I'm having trouble installing my (boxed) VS X3. I have a RAID array. I assume the delayed write failure has something to do with RAID. I see that there are work arounds but all seem laborious and complicated. To your knowledge is there a simpler fix ?
centurion3
Zion21
motherboard: Asus P5Q
processor: Core 2 Duo
ram: 4GB
Video Card: Radeon 4870
sound_card: Asus Integrated
Hard_Drive_Capacity: 1Tb
Re: Delayed write failure
Post by Zion21 »
centurion3 wrote:Steve,
I'm having trouble installing my (boxed) VS X3. I have a RAID array. I assume the delayed write failure has something to do with RAID. I see that there are work arounds but all seem laborious and complicated. To your knowledge is there a simpler fix ?Image
centurion3
I have heard that some people have had success installing & running VSX3 under a virtual machine. I'm not sure if that was the kind of answer you were looking for though.
nightlogger
System_Drive: E
motherboard: P7P55D Pro
processor: Intel i5 650 1156
ram: 8 GB
Video Card: Nvidia GT 220
sound_card: VIA HD audio on motherboard
Hard_Drive_Capacity: 1.5 Tbyte
Re: Install and Activate VSX3
Post by nightlogger »
I am having a problem installing VSX3,first time install of Corel. When I come to the install window where you put the serial number it accepts the number starts Initiating the install configuring direct X, then gets an error -9. It says your system is not properly modified. I have Direct X 9 on my system, so I am not sure what to do. I bought Corel Photo Essentials 4 in a bundle with VSX3 and it intalled fine. Any thoughts as to what I do next?
Welcome to the forums,
I'm not sure what your screenshot has to do with your question, but if so, you need to check the box beside I accept the terms..... Then the Next button will become active.
nightlogger
System_Drive: E
ram: 8 GB
Actually I did and entered the serial number and then the error occured. I think now it is a corrupted file. I tried to download the trial version and the integrity test fails when the download finishes. I am about to try downloading again for the third time. This is getting really annoying. :evil
Still can't get VSX3 or PSPP X3 to install on my system,here is a picture of what happens when the insallation stops.
Has anyone had this type of problem with these softeware application suites?
Thanks Bart
richlux
Post by richlux »
Is there an easy way to figure out what files are used by an X2 project? I don't want to keep X2 and X3 on the box, so I want to uninstall X2, but I want to make sure I keep a copy of all the images and sound files that I used in my X2 projects so they are available when I convert the X2 project to X3. Any recommendations on how to do this?
Thanks,
Rich
Heesenproductions
motherboard: ASUS P5Q-EM
processor: Intel Core2 Quad Q6600 2.40 GHz
ram: 6GB
Video Card: NVIDIA GeForce 9600 GT
sound_card: Realtek High Definition Audio onboard
Hard_Drive_Capacity: 1500GB
Monitor/Display Make & Model: Philips 192E [Monitor] (18.5")
Post by Heesenproductions »
I download VSX3 Trial (file name: VSX3_Pro_TBYB (2).exe) from www.corel.com, a huge file of 1.2GB. After download I got the following error when trying to install: " >SetupNew\setup.cpp (140) PAPP:...
PVENDOR:...PGUID:...$@Windows Vista Service Pack 2 (600) IE Version: 8.0.7600.16385." Now what does this mean? My PC is running Windows 2007 Professional. A look at the download folder gives the file size as 860MB. I used Firefox 3.6.8 to download and the said Corel Download Manager never showed up. Now what now? I am scared to start a new Trial and end up with a corrupted file again and the download consumed a lot of my internet capacity allready. Any help is wellcome. :evil:
Sony DCR-SR100E HDD Camcorder recording in SD MPEG2 VBR9100, Upper Field first, 720 x 576, 16:9, Dolby Digital 5.1 Bit rate 448kbps
Sony HDR-XR200 HDD Handycam recording HD1080 recording in AVCHD, setting up to record in SD MPEG2 VBR9100 Dolby Digital 5.1
kiriakos
motherboard: GIGABYTE EP35C-DS3R
processor: Q6600 QUAD 2.4G
ram: 2GB
Video Card: HD5770
sound_card: CREATIVE XFi MUSIC
Hard_Drive_Capacity: 300GB
Post by kiriakos »
Hello all I hope that I am at the right thread , but I am not 100% sure .
I have VSX3 boxed , and all that I care for , are to be able to register and update the software, for total off-line use .
With the help ( instructions ) of the Corel team , and the tips about getting all the current service packs, and add-on files,
I think that I am in a good track.
But , what if I can not get on-line , and I have this nag screen about " Register to COREL " ..
That it does not look to have an option ... " Do not bother me " , but only days , until next launch ?
Is there any tips to totally deactivate this ?
Thanks.
There's no option to disable it. You must activate it within 30 days. You can activate online or by telephoning Corel.
I think the middle option is the one you are looking for!
lvldcook
processor: AMD Athlon II X4 630 2.8 GHz
ram: 6 GB
Video Card: Integrated ATI Radeon HD4200
sound_card: ATI HD Audio Device
Hard_Drive_Capacity: 750 GB
Post by lvldcook »
I posted this as a new topic, but probably should have asked here instead.
I upgraded to VSX3 shortly after I bought a new 64 bit Dell desktop system. When I download and install, the new X3 files are in the 32-bit operating system Program Files directory. The program works fine, but I want the advantage of 64 bit speed, which I understand VSX3 supports. Can I download again and somehow get the 64 bit system install files?
Thanks,
Steve Cook
Post by Black Lab »
That would be a question for customer support.
It would be news to me if there is a 64 bit version... :cry:
soufi91
motherboard: MICRO STAR INTERNATIONAL CO LTD
processor: X86 Family 6Model 15Stepping 13 Genuine Intel 2.4G
ram: 2GB
Video Card: INVIDIA Gefore 9400 GT
sound_card: Realtek HD Audio output
Hard_Drive_Capacity: 160 GB
Post by soufi91 »
hi, i just download VSX3 and when i want to intall it in my computer first is show this
then this and it's i think chanises or something like that and i don't undestand it
please help me
what should i do
