X3 trial won't install-"this installation is forbidden
TimmyTutone
Post by TimmyTutone »
I'm trying to install the trial of X3 and it unpacks, and then it allows me to accept the terms, and choose what I want installed (the flash, updates). I click next and it seems like it's gonna start and then it says this and stops: "this installation is forbidden by system policy. contact your system administrator". Yes I am logged on as an administrator.
I tried this and it didn't help:
1. Click Start on the Windows taskbar, and then click Run.
2. On the Run window, type gpedit.msc, and then click OK.
3. On the Group Policy window, navigate to Local Computer Policy, then Computer Configuration, then Administrative Templates, then Windows Components, and then Windows Installer.
4. Double-click Prohibit non-administrators from applying vendor signed updates.
5. Click Disabled, and then click OK.
I also tried this and it didn't help either:
1. Click Start -> Control Panel
2. Open Administrative Tools
3. Open Local Security Settings
4. Click Software Restriction Policies
5. If no software restrictions are defined, right click the Software Restriction Policies node and select New Software Restriction Policy
6. Double click Enforcement
7. Select "All users except local administrators"
8. Click OK
9. Reboot the machine
SOFTWARE: VSP X2, Premiere CS4, Xvid4PSP, megui, WMV encoder.
HARDWARE: Canon VIXIA HF11, Sony VX2100, Panasonic HDC-SD7
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
You might get criticised for duplicating this problem but i can understand your frustration. I have trolled the internet for an answer to this and think it is more Windows problem than a Corel one. I might be wrong, of course, I often am but perhaps Steve Jones might get to see this thread. It looks like one of those problems that he seems to relish. Perhaps he will take up the challenge :wink:
EDIT
Have just had another thought. Sometime ago I was trying to install another Corel project and that clashed with an Adobe product. I see you have Premier Pro installed !
John Mitchell
TimmyTutone
I didn't think of this as duplicating since my post about it was buried inside another thread that didn't have anything to do with installing. Hope the mods see it my way! :)
It's definitely a windows problem, but this installer is the only program to pull up that error message. That's why I wanted to start a new thread about it to see if anyone else was running into the same problem with this installer (since I've installed lots of software on this machine and have never run into this before).
I kept the installer folder (it gets deleted after you are forced to end the install, so I copied it) and there's tons of files in there including a setup.xml I was thinking there might be some type of 'check this' line in there I can "turnoff", but I can't make heads or tails of the things it's pointing to.
Here it is:
<ICA lang="use_os">
<Setups productcode="ICA.productcode">
<Msi productcode="{A49F249F-0C91-497F-86DF-B2585E8E76B7}" file="CDS\RunTime\MFC2005\vcredist.msi" cmdline="" condition="THIRD_PARTY" progresstext="***.VS2005.text" comment="" adminsupport="0" />
<Msi productcode="{7299052b-02a4-4627-81f2-1818da5d550d}" file="CDS\RunTime\MSVC2005\vcredist.msi" cmdline="" condition="THIRD_PARTY" progresstext="***.VS2005.text" adminsupport="0" />
<Msi productcode="{9A25302D-30C0-39D9-BD6F-21E6EC160475}" file="CDS\RunTime\MSVC2008\vc_red.msi" cmdline="" condition="THIRD_PARTY" progresstext="***.VS2008.text" adminsupport="0" />
<Msi productcode="DXNov2007" file="CDS\RunTime\DXNov2007\DXSETUP.exe" cmdline=" /silent" condition="THIRD_PARTY" progresstext="***.DXNov2007.text" comment="" adminsupport="0" />
<Msi productcode="DotNetFX35SP1" file="CDS\RunTime\DotNetFX35SP1\dotnetfx35SP1.exe" cmdline=" /passive /norestart" condition="THIRD_PARTY" progresstext="***.DotNetFX35SP1.text" comment="" adminsupport="0" />
<Msi productcode="{F069C491-69E6-4D9B-9A0C-B7894A1FA97C}" file="CDS\Setup.msi" cmdline="ICA_ALL_PUBLIC" progresstext="Str.ProgressText.Common" managed="1">
<Dbm productcode="{F95C8C1F-25BB-44EC-A7E6-5C17ABC6BC71}" file="CDS\VIO.msi" cmdline="MSIFASTINSTALL=7" progresstext="Str.ProgressText.Common" comment="" />
<Dbm productcode="{F8423392-2296-4748-9B66-344432459632}" file="CDS\PureHD.msi" cmdline="MSIFASTINSTALL=7 PRO=[PRO]" progresstext="Str.ProgressText.Common" comment="" />
<Dbm productcode="{F4E9851F-765E-40B7-9859-237C2724E62C}" file="CDS\DeviceIO.msi" cmdline="MSIFASTINSTALL=7" progresstext="Str.ProgressText.Common" comment="" />
<Dbm productcode="{F6246243-CF06-4E40-8A37-C3B537695C36}" file="CDS\Share64.msi" cmdline="ICA_ALL_PUBLIC" condition="64BIT_OS" progresstext="Str.ProgressText.Common" comment="" adminsupport="0" />
<Dbm productcode="{F909BD3C-8684-4ACF-B7C3-33F4F9F901B7}" file="CDS\Share.msi" cmdline="ICA_ALL_PUBLIC" progresstext="Str.ProgressText.Common" />
<Dbm productcode="{F6A76E9C-C299-4CFA-AD2A-57FE9DD68B70}" file="CDS\Contents.msi" cmdline="ICA_ALL_PUBLIC" progresstext="Str.ProgressText.Common" />
<Dbm productcode="{FB0B6DDD-DF3E-4CD6-927C-724AB854E322}" file="CDS\VSClassic.msi" cmdline="ICA_ALL_PUBLIC" progresstext="Str.ProgressText.Common" />
<Dbm productcode="{F206FEC3-F5DD-43FD-A8CF-9C46B8A6A92C}" file="CDS\VSPro.msi" cmdline="ICA_ALL_PUBLIC" progresstext="Str.ProgressText.Common" />
<Dbm productcode="{FD67D9F3-FED6-4A2E-9D6C-8C8C44DEF8FF}" file="CDS\IPM_VS_Pro.msi" cmdline="ICA_ALL_PUBLIC" progresstext="Str.ProgressText.Common" comment="" />
<Dbm productcode="{F072CA07-A781-45E4-9975-C033A73019CF}" file="ICA.msi" cmdline="ICA_ALL_PUBLIC" progresstext="Str.ProgressText.Common" adminsupport="0" comment="" />
</Msi>
<Msi productcode="{XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX}" file="ICA.msi" condition="ACTION=ADMIN" comment="Added here for admin support only, productcode is only used for local installs and should be unique -- therefore this node has a bogus one -- the other option is to explictly list all ICA files in SupportFile nodes -- NOTE the condition must be ACTION=ADMIN"/>
<Msi productcode="{7E4CB404-F1E4-4E81-A1CB-2CBB310481D1}" file="CDS\MLE.msi" cmdline="" condition="THIRD_PARTY" ignorereturn="1" progresstext="Str.ProgressText.Common" comment="" adminsupport="0" />
<Msi productcode="AVControl" file="CDS\RunTime\AVControl\Setup.exe" cmdline=' -s --NonAvDec --NonCommonBinFiles --InstDir:"[INSTALLDIR]\AVControl" --ProfilesDir:"[INSTALLDIR]" /f2"[TempFolder]\AVC.log"' condition="THIRD_PARTY" progresstext="***.AVControl.text" comment="" adminsupport="0" />
<Msi productcode="FlashPlayer" file="CDS\RunTime\Flash Player\install_flash_player.exe" cmdline=" /s" condition="INSTALL_FP=1" ignorereturn="1" progresstext="***.FlashPlayer.text" comment="" adminsupport="0" />
<Msi productcode="WMEncoder" file="CDS\RunTime\WMEncoder\WMEncoder.exe" cmdline=" /Q:A" ignorereturn="1" condition="THIRD_PARTY" progresstext="***.WMEncoder.text" comment="" adminsupport="0" />
<Msi productcode="WMFormat" file="CDS\RunTime\WMEncoder\WMFDist11.exe" cmdline="/Q:A /R:N" ignorereturn="1" condition="THIRD_PARTY" progresstext="***.WMFormat.text" comment="" adminsupport="0" />
<Msi productcode="CommonData" file="CDS\RunTime\CommonDataInstaller\setup.exe" cmdline=' /s /z"/qn"' condition="THIRD_PARTY" ignorereturn="1" progresstext="***.CommonData.text" comment="" adminsupport="0" />
<Msi productcode="Quicktracks5" file="CDS\RunTime\Quicktracks5Installer\setup.exe" cmdline=' /s /z"/qn"' condition="THIRD_PARTY" ignorereturn="1" progresstext="***.Quicktracks5.text" comment="" adminsupport="0" />
<SupportFile file="CDS\RunTime\MFC2005\*.*" />
<SupportFile file="CDS\RunTime\MSVC2005\*.*" />
<SupportFile file="CDS\RunTime\MSVC2008\*.*" />
<SupportFile file="CDS\RunTime\DXNov2007\*.*" />
<SupportFile file="CDS\RunTime\DotNetFX35SP1\*.*" />
<SupportFile file="CDS\RunTime\AVControl\*.*" />
<SupportFile file="CDS\RunTime\Flash Player\*.*" />
<SupportFile file="CDS\RunTime\WMEncoder\*.*" />
<SupportFile file="CDS\RunTime\CommonDataInstaller\*.*" />
<SupportFile file="CDS\RunTime\Quicktracks5Installer\*.*" />
</Setups>
<FeatureTree>
<Feature name="Str.Feature.MainApp" desc="Str.Feature.MainApp.Desc" property="MainApp" expanded="1" size="0" sizerfn="0">
<Feature name="Str.Feature.MainApp.Video" desc="" property="Video" size="100000" sizerfn="0" required="1" />
<Feature name="Str.Feature.MainApp.VSPro" desc="" property="VSPro" size="100000" sizerfn="0" required="1" />
<Feature name="Str.Feature.MainApp.Share" desc="" property="Share" size="1600000" sizerfn="0" required="1" />
<Feature name="Str.Feature.MainApp.DeviceIO" desc="" property="DeviceIO" size="100000" sizerfn="0" required="1" />
<Feature name="Str.Feature.MainApp.MLE" desc="" property="MLE" size="200000" sizerfn="0" required="1" />
<Feature name="Str.Feature.MainApp.PureHD" desc="" property="PureHD" size="200000" sizerfn="0" required="1" />
<Feature name="Str.Feature.MainApp.VIO" desc="" property="VIO" size="100000" sizerfn="0" required="1" />
<Feature name="Str.Feature.MainApp.IPM" desc="" property="IPM">
<Feature name="Str.Feature.MainApp.IPM.IPM_T" desc="" property="IPM_T" />
<Feature name="Str.Feature.MainApp.IPM.IPM_T.PRO_T" desc="" property="PRO_T" size="29000" />
<Feature name="Str.Feature.MainApp.IPM.IPM_T.ULT_T" desc="" property="ULT_T" size="29000" />
<Feature name="Str.Feature.MainApp.IPM.IPM_PF" desc="" property="IPM_PF" />
<Feature name="Str.Feature.MainApp.IPM.IPM_PF.PRO_PF" desc="" property="PRO_PF" size="29000" />
<Feature name="Str.Feature.MainApp.IPM.IPM_PF.ULT_PF" desc="" property="ULT_PF" size="29000" />
<Feature name="Str.Feature.MainApp.IPM.IPM_TD" desc="" property="IPM_TD" />
<Feature name="Str.Feature.MainApp.IPM.IPM_TD.PRO_TD" desc="" property="PRO_TD" size="29000" />
<Feature name="Str.Feature.MainApp.IPM.IPM_TD.ULT_TD" desc="" property="ULT_TD" size="29000" />
<Feature name="Str.Feature.MainApp.IPM.IPM_R" desc="" property="IPM_R" />
<Feature name="Str.Feature.MainApp.IPM.IPM_R.PRO_R" desc="" property="PRO_R" size="29000" />
<Feature name="Str.Feature.MainApp.IPM.IPM_R.ULT_R" desc="" property="ULT_R" size="29000" />
</Feature>
</Feature>
</FeatureTree>
<SourceFiles>
</SourceFiles>
<RestartManager>
<App file="[INSTALLDIR]vstudio.exe" />
<App file="[INSTALLDIR]UVS.exe" />
<App file="[INSTALLDIR]BurningApp.exe" />
</RestartManager>
<UserFiles>
</UserFiles>
<Properties>
<Property name="ICA_DefaultUILang" value="en" comment="use whatever language you want to default to instead of showing Select Language DB" />
<Property name="ICA.Dlg.AllowDrag" value="1" />
<Property name="MAX_PATH" value="90" />
<Property name="AcceptLicense" value="0" />
<Property name="DisFeature" value="1"/>
<Property name="CDS_***_IMAGE" value="0" />
<Property name="CDS_***_VIDEO" value="0" />
<Property name="CDS_***_MUSIC" value="0" />
<Property name="ShowInstalliTune" value="0" />
<Property name="ShowInstallQT" value="0" />
<Property name="ShowInstallFlash" value="1" />
<Property name="ShowInstallLightScribe" value="0" />
<Property name="ShowCleanPerUserFolder" value="1" />
<Property name="INSTALL_ITUNE" value="0" />
<Property name="INSTALL_QT" value="0" />
<Property name="INSTALL_FP" value="1" />
<Property name="INSTALL_LS" value="0" />
<Property name="CLEAN_PERUSER" value="1" />
<Property name="ALLOW_PRODUCTUPDATES" value="1" persist="1" comment="needs to be saved from admin installs, Script.dll will default it off if we are running an admin setup" />
<Property name="ICA.Default.InstallFolder" value="Corel VideoStudio Pro X3" />
<Property name="ICA.Default.InstallDir" value="Corel\Corel VideoStudio Pro X3" />
<Property name="ICA.LogOptions" value="voicewarmup" />
<Property name="CACHE_SETUP_SOURCE" value="1" />
<Property name="CACHE_SETUP_SOURCE_SHOWUI" value="Show" comment="Hide - will remove the Copy Installation Files option" />
<Property name="ICA.Maintenance.Mode" value="Remove" comment="sets the default radio button on ARP.htm" />
<Property name="Include.Default" value="EN" />
<Property name="SHOWSERIALDIALOG" value="false" comment="true will show the serial number dialog, false will skip it"/>
<Property name="Include.EN" value="1" />
<Property name="PRODUCTSHOWSERIAL" value="1" />
<Property name="SERIALNUMBER" value="VS13T22-X5Q2P6N-DPRK6DH-GYVBALJ" persist="1" comment="When you remove the hardcoded serial number, just set the value to blank, do not remove this node or the SERIALNUMBER will not be saved after you perform an admin install " />
<Property name="PIDPREFIX" value="VS13" />
<Property name="DTAFILENAME" value="VS13" />
<Property name="PCUSOURCEID" value="910035" />
<Property name="PCU_LICID" value="540228697" />
<Property name="NLRFILE" value="VSPCUNLR.dll" />
<Property name="LICENSEID" value="540228697" />
<Property name="PCUURLLANG" value="EN" />
<Property name="PRODUCTREGKEY" value="VS Pro\Version13" />
<Property name="PRODUCT" value="VS Pro" />
<Property name="SerChckModule" value="SerChck.dll" />
<Property name="SUITE" value="99" />
<Property name="PLAYBACKSKU" value="0" />
<Property name="INSTALL_TYPE" value="PRO_T" />
<Property name="IPM_SU" value="0" />
<Property name="PRO" value="2" />
<Property name="PRO_PR_VER" value="13.0" />
<Property name="MSIFASTINSTALL" value="7" />
<Property name="MUI_SUPPORT" value="TRUE" />
<Property name="ARP_ICON" value="vstudio.ico" />
<Property name="MLE_SKU_ID" value="VSPRO" />
<Property name="VS_SKU" value="VS_PRO_ESD" />
</Properties>
</ICA>
mitchell65
ram: 4Gb
Sorry but that might as well be written in ancient Greek as far as I am concerned. Let's hope for a bit more brain power than I have :oops:
John Mitchell
TimmyTutone
Yeah, I don't even know if that is used or would do anything, but since 12 hours on google wasn't a help I started getting crazy - thinking WAY outside the box. Sigh. If X2 would just work I wouldn't have to do that.
I can't remember - did 11.5+ have the blip problem when editing AVCHD files?
mitchell65
ram: 4Gb
TimmyTutone wrote: I can't remember - did 11.5+ have the blip problem when editing AVCHD files?
Don't know I only started with X2. I'm one of the newer fellas as Sinatra once said!
John Mitchell
And it's definitely not a clash between Adobe and Corel. I have had the X3 Beta, YBYB and now the full download version installed on the same computer as I have Adobe Premiere CS4, and all work happily...
But that is all I can offer -- apart from hoping Steve might take this up soon!! :oops: :cry:
Hmmmm I am a bit concerned you might have messed something up trying to fix something.
Please try this
1. Remove the program using Windows Control Panel.
2. Make a backup of your registry.
3. Download and install subinacl.exe.
4. Create a file called reset.cmd with Notepad. Copy the text below into the file reset.cmd and run reset.cmd with administrative rights (it may take a LONG time):
cd /d "%ProgramFiles%\Windows Resource Kits\Tools"
subinacl /subkeyreg HKEY_LOCAL_MACHINE /grant=administrators=f /grant=system=f
subinacl /subkeyreg HKEY_CURRENT_USER /grant=administrators=f /grant=system=f
subinacl /subkeyreg HKEY_CLASSES_ROOT /grant=administrators=f /grant=system=f
subinacl /subdirectories %SystemDrive% /grant=administrators=f /grant=system=f
subinacl /subdirectories %windir%*.* /grant=administrators=f /grant=system=f
secedit /configure /cfg %windir%\inf\defltbase.inf /db defltbase.sdb /verbose
5. Try and install the program again.
TimmyTutone
sjj1805 - Just wanted to clear a couple of things up. First, X3 never gets to the install point so there's nothing to uninstall. 2nd, I didn't do anything with that file from the X3 installer other then look at it.
Having said that, I too am a bit concerned I might have messed something up trying to fix something since I'm seeing this error. I looked up that program you're telling me to install and it looks like it's trying to fix my permissions. I'll install it and run that script after I backup my registry and create a restore point. I'll report back on my progress.
Do/Can I uninstall Subinacl.exe after I'm done running the script?
TimmyTutone
:cry: :cry: :cry:
Nope, that didn't work. Still getting the same error. This is so weird.
Post by Trevor Andrew »
Hi Timmy
just clutching at straws here¡K¡K¡K.
It may be that you have a corrupt file.
My X3 trial download file was 626,442Kb
I know you were successful in installing on another computer.
Can you try that file on your pc¡K¡K¡K¡K
TimmyTutone
I used the same exact file that wouldn't install on the one computer to successfully install it on the other.
mitchell65
ram: 4Gb
TimmyTutone wrote:I used the same exact file that wouldn't install on the one computer to successfully install it on the other.
Do you have Norton anti virus software installed? If so how about disabling it and then trying the install! Just a thought :?
John Mitchell
TimmyTutone
Nope - Norton is awful and bloated. Haven't used that since early 2000's. Avira is the champ nowadays in virus protection. I tried it with both Spybot search and destroy and Avira turned off to no avail.
I'm not sure if I'll have time tonight since that stupid installer takes 10 minutes to unpack each time, but I'm going to temp share my C drive and try and install it off the another computer over the network, but I really doubt that's gonna help.
At this point it's like when you loose your keys and start looking in crazy places like the refrigerator.
Firstly check this thread (I was spurned to write that one based upon your problem here!)
Install and Activate VSX3 TBYB
If you are doing everything correctly then try doing the following:
On the [Start] Menu - [Run] type into the box
MSCONFIG.EXE
now untick Load System Services
untick Load Startup Items
Make sure that use original boot configuration IS ticked.
Restart the computer and try and install the software again.
When you have finished you need to return the computer back to its normal state by reversing the above changes made to MSCONFIG
