Pallettes not displaying PSPro X
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
Have lost the browser,learning centre and materials pallettes.The working screen is massive.Went to View-Pallettes and Palletets and all the missing functions are enabled.What do I do please.................Ken
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
Go to File > Workspace > Load and load either a customized workspace that you have previously saved, or the default PSP X workspace.
If that doesn't work, go to File > Preferences > Reset Preferences, select all six options and click OK.
Tim Morrison
C-Tech Volunteer
Ken Veal
ram: 32 GB
lost pallettes
Post by Ken Veal »
Thanks Tim, you are a star! ,was beginning to think that this would never happen to any one else and there was no answer except to reinstall.The former worked but I went through the pref as well.The only thing not showing now is the word Layers that was in a small blue vertical strip on the extreme right of the workspace,is this a problem.
Tim Morrison
Moderator
processor: 3.16 GHz
ram: 2GB
If "Layers" was showing like that then you had the Layers palette set to roll up to a tab. You can put it back like that by moving the Layers palette to dock with the Materials palette, then click the small pin icon on the palette's header. When your mouse is over the pin icon you should see the words "Auto hide palette". The palette will then expand when you roll the mouse over the tab, and auto hide when you move the mouse away.
After you've finished putting everything where you want it, go to File > Workspace > Save. You can then load your saved workspace to get everything back in place if needed in the future.
Tim Morrison
C-Tech Volunteer
