Express Lab errors in Paint Shop Pro X3
I purchased the program, downloaded it 2 times. When I try to use Express Lab, the program errors out and stops the program. I tried to adjust the brightness and the error occured. It also happens with High Pass Sharpen. Smart Photo Fix results in the same error. Any suggestions?
Bobb1942
Bobb1942
pdxrjt
- processor: Intel Core i7 - 4.2 GHz
- ram: 32 GB
- Video Card: NVIDIA GeForce GTX 1080
- Hard_Drive_Capacity: 10TB Int.
- Monitor/Display Make & Model: Acer 32 inch x2
- Corel programs: Paint Shop Pro 2018
Hate to sound smarmy, and perhaps other wiser brains will have more to offer, but wait for an update. My PSPX3 remains buggy (not reading tags, orienting pics the wrong way etc.) I hope an update will fix them. I do a lot of music and usually a "bug fixing" update follows shortly in a major music program! Good luck.
Update: Paint Shop Pro X3 errors with Express Lab
It is still not working. I contacted Corel and they made a couple of suggestions, none of which helped. I spent several hours removing the program and then reinstalling according to their suggestions. The best it did was work for changing the brightness, ONCE, but as soon as I tried another adjustment, the program ceased to operate and shut itself down. Think I will stay with X2 Ultimate.
pdxrjt
- ram: 32 GB
Well, I too have found a couple of errors. But I have a lot of music software and notice that everything is buggy when it first comes out.....at least I have not found anything that works well. Even if it works for me, when I go to my music boards...I see it isn't working for someone....so hang in there... I'm sure a bug fix is coming!
- ram: 2 GB
- sound_card: Intel GMA 950
And yet again.......
Please click ---> HERE <---
And.....
Please click here -->
so that we can then view your system specifications.
And.....
The program still doesn't operate correctly. Help from Corel has not been good. Nothing they have suggested has worked. Now they want me to call them on my Dime. X2 Ultimate worked correctly the first time.
- ram: 2 GB
What error message(s) do you get.
Have you looked at the Windows Error Log?
Perhaps you might find something that helps here -->
Troubleshooting your computer
This is what I do:
Start Program
Get Photo
Click on:Express Lab
Adjust Brightness
ERROR Message: Corel Paint Shop Photo Pro X3 has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Nothing found in error log
Start Program
Get Photo
Adjust Brightness
I've tried to replicate your problem however I can not get it to crash. I took it one step further and retrieved a photo from a USB external HDD, that I had to access through another PC on my Network. Now this being done, while having yet another photo open that I previously worked with in Express Lab, open. I made several alterations to the photos, but the program refused to crash.
Are you working with RAW images? Those are quit large, and can place huge demands on your system.
Express Lab Error in Paint Shop Pro X3
The Photos that I am using are .jpg.
Does anyone think it is possible that PSPP Ultimate X2 is interfering with X3?
pdxrjt
- ram: 32 GB
- ram: 2 GB
Re: Express Lab Error in Paint Shop Pro X3
Everything we do with a computer is a process of trial and elimination.bobb1942 wrote:The Photos that I am using are .jpg.
You will see from my signature block below that I have several versions of the same software installed all at the same time. However there is a reason for this - it is to assist with my dealings on this Web Board.
Is there a reason why you need to keep X2 on your machine when you now have X3? If not then I would try removing both and then install X3 again.
