I cannot prevent auto repeat at end of movie.
I don't think I had this problem with previous DVDs. If I didn't have a problem then I have no clue what I changed to cause this.
Under one project/VSP I use Share - Create Video File - MPEG - MPEG2 720x480. I don't see an other repeat type options there. And I see non under File Preferences of Project Properties.
Then another project/VSP file loads just that MPEG to create an ISO file.
Then Share - Create Disc - DVD. I have no menus. Previous DVDs I've done had no menus either so that shouldn't make a difference.
Under the jog wheel Project Settings I have auto repeat unchecked.
But when that is disabled the Clip Playback says *either* 'continue to play next clip (there are none) or 'back to menu' (there are none).
That -half- implies that *if* *both* of those two possibilities fail (next clip and back to menu) that it's *possible* it will revert to auto repeat even though it's unchecked.
Update: I noticed that for no apparent reason autorepeat was *ON* in Win Media player so I shut that off and it still repeats. Can't find a repeat option in RealPlayer but it repeats there too. I have nothing else handy to test this with.
Any clooz?
Thanks much. Have a
Jim
jb@jbarchuk.com
