I'm a great user of PSP X3 (since version 4.3) for my business, I'm a webcoder and webdesigner.
I really love this soft.
Here are my suggestions for the next version :
- Allowing to see size and position of an object (in pixel, inch or centimeter).
- Allowing to modify size and position of an object using numeric values.
- When I use Bezier, It's not possible work in zoom mode and drag an handle of a dot if it is out of the image zone. I must un-zoom to see the handle, it's not very easy to work
- Allowing to snap object each other (not only the grid and helper line)
- Allowing to delete a selection (raster mode) out of the border of the image (example : after inverting a selection of a raster layer greater than the image)
- When I modify a selection by adding or removing a part with the "lasso" (or another selection tool) in zoom mode, if the mouse is going on the border of the working window, the image is sliding. Then the existant selection is not redrawn. Not really usefull to modify the existant selection.
- When working with a selection (raster mode), displaying the total size of the selection (X and Y size)
- All raster tools such as rubber, brush, etc... are very very too slow to use when the size is to high (such as 600 for example and 1 for rigidity). I have a PC with the latest Processor and a lot of memory, no way to use these tools with high size.
- It would be very usefull to have a new gradient feature : gradient following a bezier curve, not only a line or circle.
- In the layer list, if a layer have a blend mode different than "normal" the color of the blend mode should be different
- When working with text, the input box to enter numeric values of the spacing between lines and characters are too small.
- If the option "Auto preserve" is to OFF, add in the file menu, the possibility to "Save and preserve..."
- Add the possibility to make boolean action between objects (like the pathfinde of illustrator)
- Correct the pixel selection problem with Windows Seven 64 when making a selection using the shape of an object. I use it a lot, and I have lot's of problem with this feature. Here is a little video I made to explain the problem
- Modify the color of the close cross button of an image in tabbed view
