when i try to uninstall,so i can reinstall software,it will not let me uninstall,i recieve this message-msi launcher has stopped working.i tried to find fix online,but could not find solution.
corel painter essentials 4
pa dreamer
when i try to open corel painter essentials 4,i am receiving this error message-msvcr71.dll was not found unable to locate application,try uninstalling and reinstall software.
pa dreamer
- ram: 2 GB
- sound_card: Intel GMA 950
This might work - it is an old trick I used when I wanted to carry a version of Microsoft Office around with me on a CD a few years ago.
In those days I did some computer programming at my workplace using the built in "Visual Basic For Applications" that was found in Microsoft Access and Microsoft Excel but the workplace computers were locked down by the I.T. Department. So the only way I could tweak anything at work was to pop a CD into the CD drive with a copy of Microsoft Office that could be run directly from the CD (Not installed on the computer).
When you see an error such as the above which relates to a missing DLL (Dynamic Link Library) file - then locate a copy from somewhere else.
This can be another computer or search the internet. When located place a copy of the DLL file in the installation directory of the program you are trying to run.
The next time you try to run it you will probably find that it is "missing" yet another DLL so you repeat the procedure (again and again) until eventually it runs.
Cannot guarantee this will work for you because you are using different programs and a more modern operating system than I was at the time (NT4 and XP) but you have nothing to lose by trying.
pa dreamer
pa dreamer
painter essentials 4 not working
i pop the painter essentials disk in,it will work for two days,then i start seeing the error message again,i have done this three times,put disk in it works,then error.what is causing missing dll problem?
pa dreamer
pa dreamer
also when i redownloaded painter photo essentials 4 from my paintshop pro disk,it put missing dll into painter essentials 4,i will see how long they both work.
pa dreamer
pa dreamer
pa dreamer
corel sent me the same e-mail on how to fix problem,if it did not fix problem ten days ago,why would it fix it now????????
pa dreamer
pa dreamer
the dll is there,but it keeps saying it is not found,how come when i first install disk,everything works,then within a short while,problem reoccurs,it does this with painter photo essentials too.
pa dreamer
- ram: 2 GB
Perhaps the file has not registered.
To register a dll or ocx file in Windows 7:
Click Start >Type in Search Bar:
regsvr32 <path & filename of dll or ocx>
Click Enter.
You can also use this tool
Click Enter.
pa dreamer
last night i did a clean install of windows vista ultimate and then reinstalled essentials 4 software,as of this writing,software still working.
little by little i am reinstalling my software,checking to see if i had a virus or some other software was causing conflict.
i will keep you updated.
pa dreamer
pa dreamer
as of this writing software still working,i have reinstalled all software,and no conflicts.the only thing that must have caused problem was not software related,it must have been a virus that my anti-virus and anti-spyware did not catch.just glad to have everything working right again.
thanks for your help.
pa dreamer
