I put a title on a jpeg image and then wanted to use the clone brush.A message showed that the image was to be converted to a Raster before I could do so.I right clicked where I wanted to and the X showed but the
clone brush would not work................Ken
Image changed to Raster-no clone brush
Ken Veal
- motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
- processor: 360 gigahertz Intel Core i9 900K
- ram: 32 GB
- Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
- Hard_Drive_Capacity: 1250GB SSD
- Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
- Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
- ram: 6 GB
- Hard_Drive_Capacity: 500GB
- Corel programs: PSP: 8-2023
Make sure to select the picture layer you want to use the clone brush on after you added the vector text.
Here's what I think is happening.
You're creating the text but that vector layer is still selected, remember the tools work on the selected layer only, so before you can clone onto the vector layer you need the vector layer to be a raster and it tells you this. You convert to a raster and you use the clone brush, but you're using the clone brush on a transparent layer so you're cloning transparent pixels over transparent pixels.
Just make sure the picture layer is selected before using the clone brush.
Ken Veal
- ram: 32 GB
Picture layer
As you probably realise I am new to this, how do I select the picture layer
in PSPro X
in PSPro X
- ram: 6 GB
Wow...it's been a while since I used PSPX but I think the layout is almost exactly the same.
First make sure your Layers Palette is visible. It should say "Layers" in it's title bar. This is where you will control all of the layers in your image.
If you can't find it go to your menu and select View->Palettes->Layers.
If it already has a checkbox next to it then the layer's palette is already opened.
Find the layer with a thumbnail of your image inside it. That's your picture's layer. Select this layer with the mouse. The highlighted layer will always be the active layer.
Ken Veal
- ram: 32 GB
Layers Palette
Thanks for that......but "View" does not have show layers option that I can find.There is a layers heading inbetwwen"Effects" + Objects which has headings like New Raster,New Vector,New Art Media layer but i cant find anything of use Ken
- ram: 6 GB
It's not a "show layers" option. It's a sub-menu inside the view menu called Palettes. In there you should see an option for "Layers" which will display the layers palette. The palette is where we visually arrange, create, and deal with the various layers in the picture.
There should be an option called "Palettes" in the view menu. In that menu there should be an option to show the Layers Palette.
If you still can't find it there should be a "Palettes" button on the main options bar near the top where you can also turn on the palettes.
Here's a screen shot of what I'm talking about.
As you can see here you can click the Palettes button (this option should also be in the View menu I have highlighted) or you can press F8. You should then see a dialog like the one here.
Except it will have thumbnails and names for each layer.
Ken Veal
- ram: 32 GB
Layers Palette
Thanks for all your trouble-think I have got there.This was my workflow,
and it worked! Much appreciate your help. :-
Entered Text Apply Selected "Palettes" from
Standard Toolbar (2nd row down ,left of "Zoom" ) Clicked on
"Layers" Clicked on L
a
y
e
r
s at extreme right
Layers Palette Shows instead of Materials Palette Clicked on
Thumbnail of image Used Clone tool Ken
EDIT The upper case "L" for vertical "Layers" is not displaying in the post as I have typed it, cant resolve that
a
y
e
r
s at extreme right
