Multi trim mpeg anyone???
tonyjer
Post by tonyjer »
I'm creating a new thread as the old one went cold (mortally wounded) and this has a different dimension anyway.
My challenge is to identify a glitch in a 2 hours plus video file (mpeg conversion works so there's nothing wrong with the file but the burner module won't burn to ISO or TS folders).
I am systematically splicing and dicing the project and then rendering to pinpoint but this is very time consuming.
Just wondered if you could multi trim the mpeg to save time.
Tony
Antonio y Anna
disc size
Post by Trevor Andrew »
Hi Tony
Sorry for not replying to your last post on Sunday, I don¡¦t seem to have had the Topic Reply Notification.
But from your last comments I have simulated your problem.
Earlier I created an iso file to the default folder. Some 7 Gb worth.
Now I try again and get the warning ¡¥Convert step got some problems¡¦
The option lower left DVD 4.7 G, I changed to DVD 8.5G
The process started ok.
Hope this works for you.
Funny I cant seem to cancel the burn, Esc usually does the trick but the ¡¥multiplexing' just wants to run its course. I can wait
tonyjer
Post by tonyjer »
Hi Trevor
Seems bizarre but it seems to work for to. However, I won't celebrate till I go through the whole routine and get the DVD.
Seems bizarre in a way when one is burning to ISO. I can also honestly say I've never had this problem before and I've done plenty of 7Gb plus projects in this way.
Many thanks
Tony
Antonio y Anna
