VideoStudio Pro x3
oz4me
Post by oz4me »
I have VS10 VSx2 and VS X3 trial all installed. They install to separate folders so they do not interfere with each other and X2 and X3 are compatible with each others files.
I think I will stay with X2 because of X3s retrograde step of using WinDVD2010 to render and burn
If you pay for an item IT should work
michal_h
motherboard: -----
processor: Core i5 520M
ram: 8GB DDR3
Video Card: GeForce GT 330M 1 GB GDDR3
sound_card: -----
Hard_Drive_Capacity: 120 GB SSD
Post by michal_h »
dalemccl wrote:This post is long and is only about AVCHD, so unless you have an interest in how X3 handles AVCHD you may want skip reading it.........
hi dalemccl, thanks for your AVCHD intro :D ¨
I'am now downloading X3 trial and will test it on my AVCHD files
I also would like to thanks all beta testers and hope AVCHD blips are solved
canon hf100
corel VS pro x3
dhnj
Post by dhnj »
johnrule wrote:
1.VSPX3 not stable, as it crashes from time to time.
2.Editing AVCHD *.TS files not frame accurate.
3.Pixalation at edit points.
4.Create Video File outputs a *.TS input as *.MPG
5.Create Disc re-encodes the input *.MPG & doubles the *.M2TS output file size.
6. The main stream(00000.m2ts) in AVCHD BDMV STREAM structure is corrupt
due to pixalation.
7. Authoring a 3 minute video took more than 10 minutes with VSPX3.
8. Authoring with other tool just took 41 seconds!
Hmmm...doesn't look too good. What was your "other tool" if you don't mind my asking?
JR
MultiAVCHD which is Free!
michal_h
motherboard: -----
ram: 8GB DDR3
sound_card: -----
Post by michal_h »
so after quick test It seems blips are not there!!! great 8)
I will check files also on plasma through ps3 to see if there is some picture deterioration
and what is also big difference I would say that workflow is much faster (compared to X2): preview etc.
canon hf100
corel VS pro x3
Post by Black Lab »
Ken Berry wrote:My major complaint with X3 is not to do with the editing module, but with the supplied authoring/burning module, which is simply none other than Corel Digital Studio 2010. The burning module of that suite is -- at least to a number of us -- quite slow to load and react. Its interface is rather obscure -- so I hope they provide adequate documentation for its "hidden" controls... From my own point of view, it simply does not seem to refer to HDV as an acceptable format at all -- though admittedly seems to handle AVCHD well, and allow -- after one of the somewhat obscure processes I mentioned above -- production of an AVCHD folder, as well as a standard Blu-Ray folder.
Sort of like having a band with all the best instruments; Gibson Les Paul, Marshall amps, etc. Then you finish it off with a Fisher-Price microphone... :?
Might have to after spending all that $$$ on the instruments... :lol: :lol: :lol:
Post by Black Lab »
Well, when spending the $$$ for a PRO video editor (as the name leads you to believe) I wouldn't expect a Fisher-Price authoring/burning module. :wink:
michal_h
motherboard: -----
ram: 8GB DDR3
sound_card: -----
Post by michal_h »
michal_h wrote:so after quick test It seems blips are not there!!! great 8)
viewed on 50''plasma no picture deterioration :D
no blips :D
excelent
canon hf100
corel VS pro x3
philip_l
Post by philip_l »
While they install to separate folders that is a shed load of DLLs that are shared and these are updated to the versions used in X3. This hopefully should not cause any issues (they are designed to be shared but I don't trust Corel to have done any testing with the new libraries to older products) so if you find X2 behaving differently this is the likely reason.
Take a look at Program Files\Common Files\Ulead, you will find a lot of files with December timestamps after installing X3, these would have placed X2 versions.
Regards
Phl
stelch
motherboard: Fujitsu Siemens
processor: Intel Xeon processor E31240 8 MB 3.30 GHzz
Video Card: NVIDIA Quadro 2000 1GB
sound_card: Realtek
Hard_Drive_Capacity: 2 x 1 Terr
Post by stelch »
Where is the manual in this version?
Stelios
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
An earlier poster on this thread asked if x3 supported AVCDH Lite. According to this blurb on Corel's site, answer YES
"AVCHD™, AVCHD™ Lite and BD camcorders"
John Mitchell
dalemccl
Post by dalemccl »
philip_l wrote:Hi
The transitions blips do indeed seem to be gone, as reported by one of the mods who was a beta tester. Yea!
My findings were the blips were still there coming out of a transition just hidden by the decoder better.
If you try a simple crossfade transition then smart render that out, then reimport that clip to the time line and then use the Create File and create a DVD output then watch that, how is the crossfade?
If you turn off the hardware decoder in VideoStudio (Settings - Preferences) under one of the tabs, then watch the smart rendered AVCHD file in VideoStudio full screen what do you see when it leaves the transition, I see a noticeable blip, like 2 or 3 frames have frozen.
Regards
Phil
Phil,
Maybe the "blips" you are seeing are different than the ones I was referring to. The blips I said seem to be gone are the ones caused by duplicate video frames. When X2 renders AVCHD it actually repeats two frames at or near the end of transitions. For example, if the the frame sequence should have been frames 23 24 25 26 27, the X2-generated sequence would be 23 24 25 24 25 26 27. (These are not actual frame counts; just an illustration to show that 2 frames are repeated - in this example, frames 24 and 25).
Played at full speed the video seems to have a brief blip or jer k at the end of the transition. In video that has steady movement, such as a person walking across the scene from left to right, if you advance the video frame-by-frame using X2's transport control, you could actually see the person jump backwards and then start walking forward again because it went from frame 26 to a repeat of frames 24 and 25.
In the one project I have tried with X3 trial, a frame by frame examination of the AVCHD video generated by X3 from AVCHD clips did not have these repeated frames. I also didn't notice any freezing of frames, but I wasn't looking for that so could have missed it.
I started to try the experiment you suggested, but X3 crashed while I was playing the video frame-by-frame. I need to leave for an appointment but I'll try again later today when I get some time.
Sony XR-500V, VS Pro X2
philip_l
Post by philip_l »
Yes the blip is different in X3 when I've seen it, rather than frames repeated causing a slight jump back, this is more a freeze or a couple of dropped frames. It possibly is only visible when playing as a slight freeze, this was visible when playing in VideoStudio full screen and the hardware decoder turned off in VideoStudio.
Never crashed did it, how odd :lol:
Regards
Phil
aljimenez
ram: 24GB
Video Card: AMD Radeon R9 270
sound_card: AMD High Definition Audio
AVCHD Lite is supported
Post by aljimenez »
mitchell65 wrote:An earlier poster on this thread asked if x3 supported AVCDH Lite. According to this blurb on Corel's site, answer YES
Yes I can vouch that AVCHD Lite files from my Panasonic LUMIX camera is supported and renders correctly. I also vouch for the changes to the rendering offering many less options than in X2. I think all the options are there, but they are not presented in the pull down options. This is not good to have done this. For example, to create a Template now, one gets much more limited options than with X2... Al
User for more than 10 years.
Xyzzy2
motherboard: MSI Z77MA-G45
processor: Intel i5-3570K
ram: 8 GB
Video Card: MSI R7770-2PMD1GD5 OC
sound_card: Realtek 892
Hard_Drive_Capacity: 6.25 TB
Monitor/Display Make & Model: HP ZR24w
Post by Xyzzy2 »
Black Lab wrote:Well, when spending the $$$ for a PRO video editor (as the name leads you to believe) I wouldn't expect a Fisher-Price authoring/burning module. :wink:
I've played very shortly with this, but am I right that functionality has been LIMITED?
Ne output to disc image or folders, limited menu customization...
Locked
