Texture in text
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Texture in text
Post by Ken Veal »
How do you get texture in title text .............Ken
Ken Veal
ram: 32 GB
Texture
Post by Ken Veal »
Thanks for that Ron, I have version X, here is what I am doing, is it correct
In Material Palette click either Foreground+Stroke Color or Back Ground + Fill Color Materials Properties Box opens Tick Texture Box (top right)
Select Texture via drop down arrow Use “ + with 4 arrows” to move text
(by using it from centre of text on image) Stretch text with double headed horizontal or vertical arrows. Hover over black box with “brackets” to alter angle
of text. use transparency if required.
I would like the texture to” show more” in the text, is this just an issue of colours and size.
What does the Frame function do for you in the Mat Palette.
......................Ken
victorianartist
Post by victorianartist »
Kenneth, you can adjust the angle and scale of the texture from the box and then you can use some adjust tweaks to your image as well to enhance it. Just play with it until you are satisfied. Not all things work the same with each image or texture.
Or, you can use a plugin texture program to get the effect you want.
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Post by Tim Morrison »
You might find that using a Pattern gives you the result you want.
A texture is added to the chosen material as varying opacity, so its appearance also depends on the colour of the underlying layer that shows through the sections of lower opacity. You may even need to have second layer of text of a particular colour underneath your textured text for the effect to work properly.
Tim Morrison
C-Tech Volunteer
Trev Bowden
motherboard: ASUSTeK. M3A78-EM
processor: 2.80 gigahertz AMD Athlon 7850 Dual-Core
ram: 4gb
Video Card: ATI Radeon HD 5450
sound_card: ATI HDMI Audio.Realtek High Definition
Hard_Drive_Capacity: 2TB
Re: Texture
Post by Trev Bowden »
......................Ken[/quote]
Changes the way you select a colour. Click it and see the one next to it Is the rainbow picker if you want to change back [/img]
