Hello-
VS X2 - 12.0.98.1
I am having difficulty with DVD+R DL layer breaks. After completing the edits, saving the work as a video file and attempting to burn with any third party software I keep getting "Can't find Layer Break" or something close to that depending on the program. I use IMGBURN predominately. This occurs whether I save the video file in VSX2 as a DVD video or an ISO file and attempt to burn to a DVD+R Dual Layer disc.
I have to resort to another 3rd party software to insert layer breaks etc. which is not only time consuming but shouldn't have to happen.
I only use Verbatim discs and this has happened on different burners on different PC's. However the disc make is moot since I cannot get to the point of burning.
Is there a setting in VS that I must make in order for this to be avoided?
Thank you.
DAC
Vista 32bit
Core 2 Duo 2.0
4GB RAM (3GB recognized)
2TB HDD space available
DL Layer Break Issues
I'm not an expert on this... Somewhere I read that the layer-break has to be at a chapter-point. (It's my understanding that this is requirement of the DVD spec., not Video Studio.) Do you have a chapter somewhere around the middle of the program?
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
bass_player
I have run into the same problem.
Here is my solution. I render the entire movie to a "DVD" file from VS12 -- (AUDIO_TS and VIDEO_TS). Then I put imgburn into the "Build" Mode and proceed to burn either a disk OR an image file.
imgburn will figure out all reasonable layer break points for you and give you some options.
VS does not create a layer break at all, nor does even the much fancier and more expensive ($599) Vegas Pro. If you burn an image from either of these, you will not get it to burn with any burner software that I know of. The ONLY burning software that has NEVER failed me is good old FREE imgburn.
If imgburn can't find a break point, it will give you a dreadful message, indicating that you are dead meat. At this point, you will need to use the method from the imgburn forum and create a layer break with VOBreaker.
The LB problem often occurs when you have very long spaces between your chapter points. imgburn 'tries' to find a chapter break for the layer break position and if there isn't one at a reasonable place, it apparently gives up.
Keep on thumpin'
