Video source: Panasonic SD9 Camcorder
OS: Windows 7
I have found when converting video from VideoStudio X2 Pro some clips show drop outs, the drops are around a random 10% block of the video within the frame that gets stuck for a couple of frames.
The drop outs appear in the same places in each clip that is affected. I've managed to troubleshoot this, details below:
1) The AVCHD file copied from the camera card plays without the drop-outs on the PC, either directly or when watching from within VideoStudio and from the camera.
2) When converted to a different format via the Share option in VideoStudio (can use custom or preset video types) the drop-outs appear. Any destination codec seems affected.
3) I tried the Neoscene codec, when converted via VideoStudio to the Neoscene format the drop-out is there.
4) When converted by Neoscene's own interface outside of VideoStudio, so I assume using it's own AVCHD decoder, no drop out!
5) I can add the Neoscene encoded video to VideoStudio and export it using share to any format, no drop outs.
The above is repeatable on different computers.
My conclusion is that there is a problem with the AVCHD codec that VideoStudio is using, it is flawed in someway when decoding and passing to another codec for re-encoding.
Anyone seen this before?
I also have the issues as reported (blip) when using the AVCHD video with smart rendering around transitions.
So all in all very disappointed with VideoStudio
Is it possible to get VideoStudio to use a different codec than it's own for AVCHD?
Regards
Phil
