Text on image frame
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Text on image frame
Post by Ken Veal »
PSProX
I am trying to enter text over a jpeg still image on top of a Mat Gold frame surround.After entering the text it will not show.I get a small line with various very small icons on it.Here is what I am doing.
Click text tool click on frame enter text click apply the cursor is now a cross hair with an A next to it text is not showing hovering on the line gets either a horizontal or vertical double ended arrow with a white box, a cross with 4 arrows or what look like two brackets help please ..... Ken
What color are you using for your text? By what you're describing, the text is there, however blending in with the frame. What point size are you using for your text? On images that you're intending to print, a 16pt font can be very, very small.
In the Materials Palette, make sure the fill is not set to transparent. PSPP is very versatile, in that you can fill your text with solid colors, gradients, and textures. This goes for both the fill and stroke, which is the outline. So you can have text that has an outline, but no fill, fill but no outline.
Ken Veal
ram: 32 GB
Text
Post by Ken Veal »
Thanks Ron,
Think size was the problem, although I still had to "stretch"
72 to get it bigger
Tim Morrison
Moderator
motherboard: Asus P4533
processor: 3.16 GHz
ram: 2GB
Video Card: Radeon HD4650
Hard_Drive_Capacity: 2.6 TB
Monitor/Display Make & Model: HP LP2275W
Re: Text
Post by Tim Morrison »
Kenneth Veal wrote:Think size was the problem, although I still had to "stretch" 72 to get it bigger
You'll notice that there are two "Units" for text size, "Pixels" or "Points". Use points if the image is to be printed and the text size will be related to your image's resolution. 72 point text will be 1 inch high. (1 inch from the top of a capital letter to the bottom of a letter with a tail like a 'g').
Use Pixels if the image is for screen display.
Most importantly, you don't have to stick to the sizes in the drop down list. You can type in any size you like from 1 to 1638 pixels. To change the size of existing text, it needs to be highlighted in the text entry box, type in the value in pixels and press enter.
Tim Morrison
C-Tech Volunteer
Ken Veal
ram: 32 GB
Text size
Post by Ken Veal »
Thanks for that Tim-------------very helpful......Ken
