Still Captures From Vid's
maximus01can
- processor: Intel Core i7-2670QM CPU 2.20GHz
- ram: 16 Gb
- Video Card: NVIDIA GeForce GTX 570M 4095 MB Total available gr
- Hard_Drive_Capacity: 1Tb
Howdy,
Been looking through the posts and searching, but can only find info on capturing video, not stills. With that said. I have a sony HDR-HC9 camcorder that I've pulled quite a bit of video into VS11+ and wondering if I have the settings correct to get the best still pics off the video. The footage is all captured in HD (1080) so I've thought the captured stills should be quite impressive, but not always. It also seems as though the aspect ratio somehow changes as the captured stills seem stretched vertically somewhat to somehow fit a 4:3 type scenario. The footage is all shot in 16:9 as well so not sure. Any links or settings I should check to ensure I'm getting the best captured stills would be much appreciated. All I do is sift through the footage till I find a frame I like and use the "Capture Still" button. Is it that simple or is there some other tweaks I can do to get the highest quality pics from the vid.
Cheers and thanks in advance,
Max
Max
This is just a guess, but if it's 1080i (interlaced) that might be part of the problem. It might not always be capturing the "matching" upper & lower fields.The footage is all captured in HD (1080) so I've thought the captured stills should be quite impressive, but not always.
I don't know how Video Studio handles this... You might have to fix it with your photo editor...It also seems as though the aspect ratio somehow changes as the captured stills seem stretched vertically somewhat to somehow fit a 4:3 type scenario. The footage is all shot in 16:9 as well so not sure.
[size=92][i]Head over heels,
No time to think.
It's like the whole world's
Out of... sync.[/i]
No time to think.
Out of... sync.[/i]
Save current frame as image
Hi Max
If you capture the still image (save as still image) or via ¡¥ clip menu¡¦
Then you will capture an image the same size of the video frame.
Not all video frames are actually 4:3 or 16:9, most use Non Square Pixel rendering to achieve these.
As still images do not use non square pixel rendering the image may look distorted
If you switch to Project playback and Tools¡XSave current frame as image¡Xwill save an image as you see in the preview window.
Make sure your project properties reflect the video properties, especially the frame size.
maximus01can
- ram: 16 Gb
maximus01can
- ram: 16 Gb
Follow Up
I brought the video clip from a DVD VOB file created previously since I didn't have the origional captured mpeg2 file only the DVD files I created. I just changed the extension on the VOB file to .mpg since VS won't bring in a VOB file directly and then proceeded to capture stills from the video. The results were pretty good but (size or resolution??) topped out at 720 x 480 which makes sense since that's the best a DVD can do without being Blue Ray I believe. So when opening it in windows pic and fax viewer the pic displayed is much smaller dimensionally than if I am able to capture the still directly from the source captured mpeg2 video stream. Trevor, would this be where doing the procedure you explained below would give a little larger overall pic with basically the same quality?
Cheers,
Max
Thanks muchIf you switch to Project playback and Tools¡XSave current frame as image¡Xwill save an image as you see in the preview window.
Cheers,
Max
mitchell65
- ram: 4Gb
Oh but VS does import VOB files directly. Go to "File" "Insert media File to timeline/library" then choose "Insert Digital media". In the Select a title window click "Import from folder" Navigate to the VIDEO_TS folder that contains your VOB file. Click OK then click on the Title in the Import window and click import.maximus01can wrote: since VS won't bring in a VOB file directly
BTW When you create an SD DVD from whatever source files the frame size will be the standard DVD for the area in which you created the DVD either PAL (720 x 576px) or NTSC (720 x 480px) So obviously a still image taken for a VOB file will be as those dimensions. It will look small on your monitor. The higher the monitors resolution, the smaller the image will look.
John Mitchell
maximus01can
- ram: 16 Gb
maximus01can
- ram: 16 Gb
Oh, one more thing while on the topic. When I've done a project and save the output files as DVD with a resoloution of 720 x 480 and I don't believe that's HD. In the spec's it says the camcorder does full HD at
Video Resolution : Full HD 1440x1080
Still Actual : 3040K Pixels (4:3), 2280K Pixels (16:9)
Still Picture Resolution : 6.1 megapixel
Can I ouput files that give a higher resoloution given this source? Then if I need to recapture stills in the future from that vid, they will be of better quality than what I'm outputting at now even though I don't have a player to run them on. Will VS 11+ give a higher resolution output files or is there a better way to go about outputting files to keep the best quality just in case the origional capture is lost.
Thanks and Cheers,
Max
Thanks and Cheers,
Max
VS Pro X7, Sony SLT A65 DSLR Camera, Samsung Note 3, Ipad4
Hi Max
First of all is your video widescreen at 16:9 or standard video at 4:3?
Each of these aspects use 720 x 480px.
The pixels are rectangular, stretched to fit the frame aspect.
HD uses 16:9 aspect ratio.
If you use Clip-Save as Still Image you will save the frame from the video file at 720 x 480 for ntsc.
Please note this is not 4:3, use a calculator to check the aspect ratio
If you use Tools ¡VSave Current Frame as Image, you will use the project size 4:3 or 16:9 and the project frame size for standard definition.
OK
Edit the project properties using Mpeg 2 compression will allow you to increase the project frame size using 1980 x 1280 which is hd standard
Now capture the image again from Tools and Clip
Compare both images and there sizes.
OK
mitchell65
- ram: 4Gb
Back up all original clips to a different media (Ext. Hard Drive or CD)maximus01can wrote:Oh, one more thing while on the topic. When I've done a project and save the output files as DVD with a resoloution of 720 x 480 and I don't believe that's HD. In the spec's it says the camcorder does full HD at
Yes. Go to Share > Create Disc > Choose Blu-Ray . then uncheck create disk and check "Create Folders" Set a destination. Click "Burn" this will produce a BMDV folder. Open that folder and then open the "Stream" sub foder and there will be your M2TS file at your High Defeinition.Can I ouput files that give a higher resoloution given this source?
John Mitchell
maximus01can
- ram: 16 Gb
Thanks Trevor and M65
Hey M65,
I looked at the path you indicated below, but when I go to that path I don't have the "insert Digital Media" option.......only "Insert Video" and when I expand the filetypes there's no .VOB extension.....Something wrong with my install?
Max
Cheers,Oh but VS does import VOB files directly. Go to "File" "Insert media File to timeline/library" then choose "Insert Digital media". In the Select a title window click "Import from folder" Navigate to the VIDEO_TS folder that contains your VOB file. Click OK then click on the Title in the Import window and click import.
Max
mitchell65
- ram: 4Gb
Re: Thanks Trevor and M65
Hi Max
I dont think you have a bad install! Remember we are looking to select a folder named VIDEO_TS not a file! Below is a sequence of screenshots that may help you.
In this part you can select the whole title (all the clip) or indivdual chapters that VS has split your clip into. Easier to start with select the Title
It will take a little while to import (depending on the length of the clip of course.
John Mitchell
mitchell65
- ram: 4Gb
Hi Trevor
As Max had said earlier
But have just noticed that Max has VS 11+. Is the "Insert Digital Media" option available in that version. I only have VS 12.
I assumed it to be an SD VIDEO_TS folder that we were looking for. Whatever the choice to "Insert Digital Media" should be there!I just changed the extension on the VOB file to .mpg since VS won't bring in a VOB file directly
John Mitchell
