Crossfade timing?
Brain Champagne
motherboard: Dell Dimension 3000
processor: Pentium 4 2.80 ghz
ram: 2 gb
Video Card: Integrated Intel Extreme Graphics 2
sound_card: do not know
Hard_Drive_Capacity: 1 gb
Crossfade timing?
Post by Brain Champagne »
I want to have a clip fade to black, then the next clip fade in.
I understand there's no feature that does this, that crossfade merges the two.
I tried crossfade over a black clip but it didn't both fade out and fade in, it just faded in.
So... I put in a two second black clip in between the two.
A one second fade to black on that clip followed by crossfade for one second.
The fade in part is fine but the fade out seems to be all black in 10 frames instead of taking all 30 frames (1 second) to fade out.
What am I doing wrong? (or is it the software?)
Post by Black Lab »
A transition simply makes the two adjoining clips overlap each other. So a 1 second crossfade overlaps a half second and the end of the first clip and a half second at the beginning of the next clip. If either of the adjoining clips are a half second long or shorter, the transition will automatically be trimmed to fit. Sounds like that could be your problem.
Brain Champagne
ram: 2 gb
That's not it. Even just the 1 second fadeout-- if I go frame by frame I can see that ten frames in it's black. It doesn't take all 30 frames to completely fade out.
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
Brain Champagne wrote:That's not it. Even just the 1 second fadeout-- if I go frame by frame I can see that ten frames in it's black. It doesn't take all 30 frames to completely fade out.
Then drag the lead edge of the transition to the left to cover as many frames as you wish!
John Mitchell
Brain Champagne
ram: 2 gb
I don't understand-- which transition? I can't drag the cross-fade (which is really just a fade-in) to the left to overlap the fade out.
Post by Black Lab »
Let's just clarify. You have the following:
video clip A > 1 sec. crossfade > 2 sec. black clip > 1 sec. crossfade > video clip B
Is that correct? How long are the 2 video clips?
Brain Champagne
ram: 2 gb
Okay, I think I fixed it-- two seconds of black between clips. A one-second cross-fade (which JUST fades OUT) followed by ANOTHER one-second cross-fade (which just fades IN). Seems to do what I want.
Don't know why they can't add an effect that's Fade to black (fade out) followed by Fade In, as one effect. If I wanted things to be complicated and still not work I'd be using something by Microsoft.
Brain Champagne
ram: 2 gb
To answer your questions-- the clips are much longer than a few seconds.
I have Clip A
2 second black
Clip B
on top of the black are 1 sec crossfade and another 1 sec crossfade.
In the language I speak, cross-fade means fade out one clip as the other one fades in.... but that's not what it does here.
x fade
Post by Trevor Andrew »
Hi Brian
What version of VS are you using, and are you Pal or Ntsc
Edited
Change the black duration to 3 seconds
There is also a Fade to Black transition in the FX section
Brain Champagne
ram: 2 gb
VS 12.0.98.0 Pro (trial version) on WinXP in the US (NTSC).
I want one second fade to black then another second un-fade from black, which I think I accomplished via 2 seconds of black covered by next-to-each-other 1 second crossfades.
mitchell65
ram: 4Gb
Brain Champagne wrote:If I wanted things to be complicated and still not work I'd be using something by Microsoft.
But I thought you said it did work and if this is the most complicated aspect of Video Editing you come across you will be extremely fortunate IMHO
John Mitchell
Brain Champagne
ram: 2 gb
I got it to work, that's not the same as saying that it worked as it was supposed to.
Cross-fade means fade out then fade in, not 'pick one at the whim of the software.'
To my mind, cross fade means precisely that: fading across -- so that as one clips fades out the other begins to fade in. I do not expect it to go totally black for a period, regardless of how brief that period is... :roll:
Brain Champagne
ram: 2 gb
Okay, but that's not what it did with one crossfade.
It faded one clip out then CUT to the other clip from a black frame.
rguthrie
motherboard: MSI MAG B550 TOMAHAWK
processor: AMD Ryzen 9 5900X 120-Core Processor
ram: 64GB
Video Card: AMD Radeon RX6600 XT
Hard_Drive_Capacity: 2TB + 4TB
Monitor/Display Make & Model: ViewSonic
Post by rguthrie »
Brain,
Just so I know I'm understanding you, you're saying that the first crossfade faded out to black, but for the second crossfade, from black to video b), it just went from black in one frame to video in the next?
SFC (Retired) Ronald Guthrie (aka Alt0S4x)
VS4SE/6-11.5+/X2-X10 Ultimate/2018-2023, Pinnacle Studio 25; Ultimate; MotionStudio 3D; PI11/PIX3;Corel PainterEssentials 4
Photoshop CS5; Audacity; SonicFire Pro 6.0
Wacom Bamboo Fun Tablet
Canon Rebel T4i
