interlacing
Frank Burch
interlacing
Post by Frank Burch »
This topic is on another thread but the replies are contradictory. We need expert advice here. The facts are:
Modern flat screens and monitors require non-interlaced material. From a camcorder the TV will do the deinterlacing. But is it better to let VS do it during capture? Of course you may be able to film in progressive mode, but you may not want to. So this is simply avoiding the question. Question begging in fact. VS 10 offers deinterlacing. It must be there for something. Of course I could simply try both methods and drawn my own conclusion, but if anyone has advice on the question it would be useful. Whether SD or HD you camcorder is recording interlaced I believe. You flat screen will not accept this. The question thus concerns everyone.
Wombat
Post by Black Lab »
Talk about contradictory:
Can you clarify?
Frank Burch
Well, maybe I'm way off track, but I believe a flat screen requires progressive mode. Camcorder mode is normally interlaced. Hook up your camcorder to the TV and the TV software will deinterlace your film to show it on the screen. Alternatively you can deinterlace during capture.
Wombat
Post by Black Lab »
I understand that. What I didn't understand was that first you said the TV will do the deinterlacing from a camcorder, but then you said your flat screen will not accept interlaced video from a camcorder. How can the TV deinterlace it if it won't accept it in the first place. :roll:
Frank Burch
Jeff, you put interlaced film into the TV and the TV software converts it to progressive. A flat screen cannot show interlaced film (as far as I know).
Wombat
Post by Black Lab »
I'm confused. When you say TV are you referring to CRT TV's, and when you say flat screen you are referring to HD TV's (Plasma & LCD)?
skier-hughes
Microsoft MVP
motherboard: gigabyte
ram: 4GB
sound_card: onboard
Hard_Drive_Capacity: 36GB 2TB
Post by skier-hughes »
A CRT can have a flat screen :)
This is good info
http://www.burnyourbonus.info/hdtv-faq/faq2.html
I think though your question is where to do the de-interlacing.
My answer would be to let the tv do it.
Reason, VS for one, is a low budget application and will use rudimentary processes to achieve fair results.
You could buy a professional app to do your conversion, but spending thousands on this for a few home movies may be overkill.
The tv's are designed to take a particular signal, and deal with that, two many conversions will just muddy the water, as well as the video.
Yep, they sure can, I have a little one sitting next to my PC, that I use to preview my work. ...;)
Frank Burch
Thanks Graham, that sounds logical. Yes HD broardcasts are normally interlaced, I think, so the new TV's are equipped to convert to progressive for the LCD screen. Hence, no need to convert during capture. Converting is dangerous because of the threat of loss of quality.
Have I got it right?
Wombat
Post by Black Lab »
Yes I know. That's why I was trying to get clarification of what he was referring to. But enough of wasting my time on him.
Frank Burch
Thanks Jeff. You were indeed wasting your precious time, because you knew nothing about the subject. You were also wasting my time.
Wombat
skier-hughes
Microsoft MVP
ram: 4GB
sound_card: onboard
Frank Burch wrote:Thanks Graham, that sounds logical. Yes HD broardcasts are normally interlaced, I think, so the new TV's are equipped to convert to progressive for the LCD screen. Hence, no need to convert during capture. Converting is dangerous because of the threat of loss of quality.
yep, right
Frank Burch wrote:Thanks Jeff. You were indeed wasting your precious time, because you knew nothing about the subject. You were also wasting my time.
Well if you already knew so much, why are posing the question? I think you need to reconsider your statement! I can assure you, that you need not waste your time, here!!!
Jeff, I was just offering my confirmation, since I do own one of them, not questioning your knowledge...;)
Post by Black Lab »
Oh, I know Ron. No problem there.
And I know there are all sorts of flat screens, whether they be pc monitors, CRT TVs, or LCD TVs. But that was my point to the OP. I was simply trying to clarify.
