Color Panel - Two-Color and Multiple-Color always greyed out
NealAZ
Post by NealAZ »
I have PI 10, 11, 12SE and X3. I have never found out how to change the Color Mode in the "Color Panel" to Two-Color or Multiple-Color.
Any help on this mystery would be appreciated.
Welcome to the forums,
If you have a path object on your stage, you need to have the Path Drawing tool selected. Then in the color panel, gradients tab, click on the color..;)
NealAZ
Post by NealAZ »
Ron P. wrote:Welcome to the forums,
I tried this (I think) and lost "Mode" completely and "Gradient" as well..
Maybe a simple step by step walk thru?
I made a "new blank" image and went to the Path Drawing tool and spiraled into total confusion.
Ok I'm a little confused now, after re-reading the topic title. First here's a screenshot of the color panel, and the fly-out to edit, add, and change the gradients.
You should be seeing some gradients. You can create your own and add them to the color panel. To change the color of a path object, you just click on one of the gradients in the color panel. Below is a link to a short animated tutorial on doing that.
Color Panel Tutorial. Click on the Download link above the folder. It is a zip file that contains a SWF, a JS file and a HTML file. Once you have it downloaded unzip it, and click on the HTML document to view the tutorial.
If that's not what your having problems with, and you just can not access the gradients on the Color Panel, we may have another problem. You must be using an RGB layout, and not a black & white or gray scale.
NealAZ
Post by NealAZ »
Ron P. wrote:Ok I'm a little confused now, after re-reading the topic title. First here's a screenshot of the color panel, and the fly-out to edit, add, and change the gradients.
Corel Tech Support email: "These modes can be activated for use when you use any of the Fill Tools except for the Texture Fill Tool. Kindly click on any of the Fill Tool in the Tool box."
