I install X2.
Then before opening or runing the program I install SP1 patch.
Then I install the SP2 Win7 patch.
Then I run the program to se how it works - I doesn't, so I try the DirectX update but it does not fix.
I have also tried the above and running the DirectX update before running X2 but that doesn't work.
If I do it any other way running SP2 Win7 patch removed my version number and serial number from the 'about' page.
I am currently at 12.0.96.1 with Win7 patch applied.
I just cannot figure it out. I would try a fresh install of Windows 7 but it's just not worth it as I can run the program and have made some nice vids for the family but not being able to use the X2 menus or burn DVD's is a bit of a pain.
But not the end of the world.
x2 unable to burn disc - next button problem unresolved
I have Windows 7 x64 and X2 with all the updates as recommended. My version says 12.0.98.1 Pro.
I have the same problem as others, I can build out nice DVD menus and even preview the menu, however the Next button will not advance to burn/author the DVD. Nothing happens. Pretty frustrating when you just spent 2-3 hours making a nice menu system, all for nothing. I hope this gets resolved soon.
Thanks for the tip on Windows DVD Maker. Will give it a shot.
- ram: 2 GB
- sound_card: Intel GMA 950
Re:
Just to put my mind at ease.... going back to our earlier concerns that you might have been the victim of being an innocent purchaser of either a used or SE version (OK it was shrink wrapped - anyone doing a scam big style would get a shrink wrap machine) did you mean there was a problem with your serial number?Damnome wrote:Hi - no I have a genuine copy bought a few weeks ago in a box delivered from Amazon
It's VideoStudio Pro X2 Ultimate - it came in a shrink wrapped box and I've tried it with and without WinDVD9 DVD copy6 and WaveLab which come with X2 Ultimate.
It is also registered online with Corel and I have an enquiry pending with them using my serial number.
I have uninstalled and reinstalled again- just to try again! and now have my serial number and version showing.
I did this by installing and before running X2 running the patches one after another and then running X2 so my serial number shows fine now.
When you say you uninstalled / reinstalled.
HOW did you UNINSTALL - was it via the Windows Control Panel?
If so then try this other method
How to manually remove VideoStudio X2
Re: x2 unable to burn disc - next button problem unresolved
I have to say that I haven't burned an actual disc with VS in years. Not because of any problems, but because I am usually burning multiple discs, sometimes at different times, so it's easier for me to burn to DVD folders then burn the discs with a third party app. I happen to use Nero too. Never have problems.
Jeff
Dentler's Dog Training, LLC
