Flash Player and VS 11+
Ken Veal
motherboard: msi mpg z390 gaming edge ac lga 1151 ddr4
processor: 360 gigahertz Intel Core i9 900K
ram: 32 GB
Video Card: EVGA GeForceGTX 760 2GB GDDR5 PCI E 3 0
Hard_Drive_Capacity: 1250GB SSD
Monitor/Display Make & Model: Samsung U28E90 28” UHD 4k
Corel programs: PaintSPro2021Ult.PhotoMirage.VS.2020 Ult
Post by Ken Veal »
I have had an invite to update Adobe Flash player, do I recall that this will cause problems with VS? ....................Ken
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
Hi Ken
If your existing Flash Player is working OK then leave it. If it ain't broke, don't fix it is my view albeit a very humble one!
John Mitchell
Ken,
I've personally have had this happen to me on several occasions, and recently. If you upgrade your flash player via an internet invitation to do so, you will most likely have to re-install the flash player version that came with VS. So as John advised, if it 'aint broke, don't fix it..
Ken Veal
ram: 32 GB
Flash player
Post by Ken Veal »
Thought it might be something like that, will leave well alone then--thanks
tonyjer
Post by tonyjer »
I've already installed the update!!
What do I need to do now?
Antonio
Antonio y Anna
mitchell65
ram: 4Gb
tonyjer wrote:Hi
Antonio
Think this has got in the wrong thread somehow!
John Mitchell
Tony,
If you're referring to the internet flash player update, first check to see if it affected VS. Launch VS and go to the Flash animation library. Select one, and press play on the preview. If it plays then you're ok. If not then you need to re-install the flash player that came with VS.
You need the install CD, or if you purchased an ESD (download) version, you will need to unpack it to somewhere on your system. This can be done with WinZip or even a freebie like ZipGenius. You right click on the downloaded VS installer file, and from the menu select (winzip) then from that menu you should have the option to Extract. Extract it to a folder. Once that is completed, look inside the folder where you extracted the files, for one called flashplayer7_winax.exe. It generally is kept in the Utilities/Flash Player folder. Run the flashplayer7_winax.exe file, which will install that version. The flash animations should now work again..
Zip file uploaded to my Sky Drive Account:
FixForFlash
Regards, Steve J - Web Board Admin
tonyjer
Post by tonyjer »
Many thanks for these replies.
Antonio
Antonio y Anna
