Problem import Jibjab MPEG1 to edit
LGO
motherboard: Intel Corporation D915PBL AAC67720-301
processor: 3.20 gigahertz Intel Pentium 4
ram: 3 gb
Video Card: ATI Radeon X300-X550-X1050 Series
Hard_Drive_Capacity: 200-750gb
Post by LGO »
This is bizarre . . . Been using VS for a decade and never run into this before!
Made some silly videos using Jibjab (http://sendables.jibjab.com/) which you can download into a MPEG-1 file to your PC for permanent storage. Fine.
The MPEG-1 file created is 425x319, VBR, 24 fps, with 44,100 16 bit aud. at 160 kpbps. It plays fine using Windows Media Player.
HOWEVER . . .
When I import into VS to edit and change to a wmv file, the video is black and white and "askew" like the following image . . .
Any ideas about this????? Seems really screwy that the mpeg files plays fine in Windows Media Player, but VS has problems with it!
Many thanks for some guidance on this . . .
LGO
Proud VS user ver. 3, 4, 5, 7, 8, 10+, ProX2, and ProX4
Currently - VS ProX4 14.2.0.23
C3DPS ver 1.0.1
GIF Animator
mitchell65
motherboard: Dell Inc. 04GJJT A00
processor: 2.80 gigahertz AMD Athlon II X4 630 Quad Core
ram: 4Gb
Video Card: ATI Radeon HD 4200
Hard_Drive_Capacity: 560Gb Sata
Post by mitchell65 »
When you say "When I import into VS to edit and change to a wmv file" What exacly do you mean. Are you trying to create a wmv via "Share" or have you converted the file in a converter software? Perhaps you are only supposed to keep the original file as is and not edit it. It may have a piracy protection system!
John Mitchell
LGO
ram: 3 gb
Post by LGO »
Hi, Mitchell, and thanks for replying.
I only "insert" the mpeg-1 file into the timeline and this phenomena happens. Have not done any editing.
The goal is to trim the start of the file with the advertising (I paid for the download so I don't want to see advertising!) and then create a WMV file using the "Share" feature. Obviously, since the video doesn't look right when inserted, I have not done any editing or saving as a WMV file.
Piracy protection system? Hmmmm, hadn't thought of that, and don't think so. I also have "Brand X Elements" and it loads in that just fine. Problem is, I can't export in that as a WMV file in the same size (425x319) as the original mpeg-1.
Appreciate the reply, and hope you (or someone) has some ideas.
LGO
C3DPS ver 1.0.1
GIF Animator
mitchell65
ram: 4Gb
If Adobe Elements works then use it. If you want to convert to wmf try the freebie converter SUPER from here:
http://www.videohelp.com/tools/SUPER
John Mitchell
brendy03
motherboard: HP builtin
processor: Intel Dual Core
ram: 4GB
Video Card: Nvidia 7550LE
sound_card: HP built-in
Hard_Drive_Capacity: 500G
Re: Problem import Jibjab MPEG1 to edit
Post by brendy03 »
I have found out exactly the same problem today, did anyone get an answer for this? Do I need to convert to another format first?
LGO
ram: 3 gb
Post by LGO »
Brendy . . .
Never could get VS to work with this so I had to use Brand X Elements (since I had it). I would suggest you get the conversion software suggested and convert to uncompressed AVI and import that format version of your jibjab file into VS for editing.
Sorry, once I found a work around that works for me, I stopped trying to find a VS solution.
Good luck and let us know what works for you!!!
LGO
C3DPS ver 1.0.1
GIF Animator
mitchell65
ram: 4Gb
If anyone would care to upload their file to a server and send me a PM with the details to download I will see if I can replicate the problem.
John Mitchell
