PhotoImpact X3 won't Launch
Program worked fine when first installed. Today when I click on Icon you get the hour glass for maybe 5 seconds and nothing else happens. iedit.exe does show up in the task manager for a minute or so then disappears. I uninstalled and reinstalled with no luck. I saw the note on the resulution mine has alway been running at 1152/864 I also tried 1064x768. Anyone have a fix for this
Bryce Grimsley
Licensed Insurance Agent
239-357-6415
800-251-4999
http://www.affordableinsurancepro.com
239-357-6415
800-251-4999
mitchell65
- ram: 4Gb
Try going to Start then All Programs then scroll to PhotoImpact X3 then in the extended window double click on PhotoImpact X3 and see if that open the program. If it does delete the Icon on your desktop, go the same route as above but when you get to the final PhotoImpact X3 right click and choose Create Shortcut and drag this shortcut to the Desktop for future use.
John Mitchell
PhotoImpact won't start.
Thanks for the tip, unfortunately still doesn't work.
Bryce Grimsley
239-357-6415
800-251-4999
239-357-6415
800-251-4999
mitchell65
- ram: 4Gb
PhotoImpact won't launch
I used regedit and remove all items that mentioned photoimpact, I thought that would fix it fo sure but it didn't.
The only thing I can think of as for some reason it thinks the screen reselution is wrong. I was trying to get a website to display correctly and changed the resulution 800 x 600. I changed it right back. This was about a week ago but I didn't try to use Photoimpact until this week so don't know if relateded to problem
Is their something in the registry that may not set correctly?
Bryce Grimsley
239-357-6415
800-251-4999
239-357-6415
800-251-4999
mitchell65
- ram: 4Gb
Tried that
I tried that yesterday. I was able to restore back a few days but when I tried to restore back 2 weeks I got a can't restore error. I tried again today and it will only let me go back to yesterday
Bryce Grimsley
239-357-6415
800-251-4999
239-357-6415
800-251-4999
mitchell65
- ram: 4Gb
Well I'm stumped! Last ditch effort try using the Search facility to make sure all trces of Photoimpact are removed from your C: drive then go to regedit and Hit Edit then Find and see if that can find any tail enders of PhotoImpact. After that I can't think what else to do. Theorectically if all traces of PhotoImpact are removed from your system then it suggests a corrupt file on your install disc. You could try installing from a download on the Corel Site then using your licence number that you have.
John Mitchell
Try excluding from D.E.P. (Data Execution Prevention). Instructions can be found here--->http://forum.corel.com/EN/viewtopic.php?p=167635#167635
mitchell65
- ram: 4Gb
