Preview not available
ramdaspillai
motherboard: Intel Corporation D865GSA AAD53275-201 133 megahe
processor: 3.05 gigahertz Intel Pentium 4
ram: 1008 Megab
Video Card: Intel 82865G Graphics Controller [Display adapt
sound_card: Realtek AC 97 Audio
Hard_Drive_Capacity: 240 GB
Post by ramdaspillai »
In Pro X2, when I go to Disc burning module, the MPEG-2 video clip I added is not showing or playing in the screen. Hence I am not able to mark chapter scenes. It is not playing with the remote control at the last but one screen.
However, I am able to burn the DVD correctly. So I assume it to be a display problem, probably directX issue.
Can any learned member advise please.
Regards
Pillai
Intel Pentium IV 3.1 Ghz
XP Prof SP2 (5.1 Build 2600), 280GB HD, 1 GB RAM
Re: Preview not available
Post by Trevor Andrew »
ramdaspillai wrote:Hi,
Regards
Pillai
Have you manually updated Direct X , there is a link at the top of this forum.
Have you installed updates from Corel for X2
ramdaspillai
ram: 1008 Megab
Thanks a lot Trevor,
I hv downloaded and updated the directx and it is now working fine.
X2 patch I did earlier.
Another request, is there any link for downloading free movie templates and also template for DVD menus?
Pillai
Hi Pillai
How many menu templates do you have?
I see lots in the Gallery
24 Smart Scene
29 Text menus
42 Thumbnail Menu
If you only have a few, have you installed the Extra Content pack that came with the X2 program.
If you need more do a search of the forum.
Or view the General Information & Downloads pages of the forum.
If you wish to create your own you will need photo Impact, how, there are tutorials available on the forum.
There are some DVD Menu Templates provided by members of the forums. They can be downloaded HERE. However due to the complexity of how the Movie Wizard works, it is not advisable to attempt to add or remove files that it must use to create the templates.
The Movie Wizard just uses existing video, image, and color clips, that are already on your system. It will cut a part of the clips you are editing, and place it in the appropriate locations along the timeline, adding overlays, other short video clips, decorations, images, flash animations to complete the video. It is possible to do everything manually, that the wizard does. Just examine the project after the wizard has dumped into the editor, if you do allow the wizard to dump it into the editor. If not, I encourage you to do so. Don't be scared to use multiple copies of a short segment of one of your video clips to produce an intro, or an outro. NLE (non-linear editing) is non-destructive, so you're not altering the video clips you've recorded and captured.
Try recreating one of the movie wizard's projects, doing so with your content. Using overlays and images that you provided, and manually placed in the timeline. Once you get that down, you'll find that the Movie Wizard is not all that great, and your personal creations are much better...;)
