hey guys ,
i am pretty sure i used to import an 8gig movie mpeg , and then create a menu , then output it to a dual layer dvd , now i cant find the option to do that , and when i import my 8gig approx size file it only appears as 4 gig in the main editing screen .
DVD Workshop 2.232 is what i have
any help .
thanks
i cant remeber how to out put to dvd9 daul layer
moonwalker
Coral
- motherboard: Asus P8P67 Pro Rev. 3
- processor: Intel Core i5 2400 Quad Core 3.1GHz Socket 1155
- ram: 8 GB
- Video Card: Gainward GT 520 1024 MB RAM
- sound_card: On Board
- Hard_Drive_Capacity: 500 GB X2
- Monitor/Display Make & Model: AOC 19 inch CRT tube
You will not see anyting that tells you that it takes dual layer. The update patch works on the burning engine. So you can burn dual layer.
Just load your movie and if it doesn't fit on a single layer, then you can burn it on dual layer using the application burning software. Unless you to prefer use other software burner.
moonwalker
ok thanks , thats a relief .Coral wrote:You will not see anyting that tells you that it takes dual layer. The update patch works on the burning engine. So you can burn dual layer.
Also , when i want to make the play button invisible it deactivates the actualy play button from the menu where you press play to view it within dvdws2. is this normal . i just did a reinstall to try to fix this , but it still keeps happening .
